Question about Samsung LA40B530 40 in. HD-Ready TV
Samsungh LA40B530 No picture but sound
When I switch on the TV, there is picture but the screen goes completely blank after 5-10 minutes. The audio continues to come but the picture dissapears completely.
If I unplug the TV and then restart after 5-10 minutes. The picture stays for 5-10 minutes and then dissapears again. HELP!!
    President:
  • 1,099 Answers
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Posted on Aug 03, 2010
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Screen goes blank but come back when TV is turned off and back on
Ur tv LCD inverter board it dead.Replaced this LCD inverter board ur tv picture will return.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 13, 2010 | RCA L32HD32D 32 in. LCD HDTV
I turn the TV on. Then about 3 minutes later the picture goes out but the sound is fine. I turn the TV off, then back on. The picture returns only to cut off againg.This happens when viewing the in TV mode...
When picture goes away do you see the screen still emitting light or does it go completely blank?
Depending on the answer there are two possiblities:
if the screen goes completely blank then the problem is likely in the TV's inverter and more specifically very likely in some of the high-frequency transformers. Best solution there is replacement.
Unfortunately inverters are often on one board with power in smaller TVs.
if the screen is still emitting light albiet being blank then the problem is more likely in the main board and, less often, in a cable.
Main boards often overheat and ICs relying on soldering contact bonds of 1/10 sq.mm. start misbehaving in all kinds of ways , including like you describe.
There's no simple cure for that problem - usually it's cheaper to replace the whole board or even the whole TV than to troubleshoot it.
Perhaps not great news, but that's what I know about it.
Bobby
http://www.coppelltvrepair.com
Jan 23, 2010 | Toshiba 20HLV86 Television
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Samsung LA40B530 40 in. HD-Ready TV Logo
524 people viewed this question
Jerry Greenberg
Jerry Greenberg
