Hi, i'm planing to install this used ibm BLAD server for a customer. http://www.itsco.de/Server/IBM_Bladecenter_E_Chassis_8677_inkl_14_x_Server_IBM_Blade_LS21_7971_i39_3108.htm But i'v never done it before. i would like to know: -it has 14 blades, bu i would like to install a single os using all the processor toghether, like a multi cpu server, since it will be used as a render farm, is it possible or i have to install a single os on each blade? -Wich kind of os can install? just server system or allso windows 7-xp 64bit? -Since it has 14 disks can they be configured as a unique raid 5? - each blade has a rj45 port, will i have to connect each port to a switch or just the chasiss ? - what is the included switch module used for? is one enaught for 14 blades or i need more? -it has 4 power supplyes of 2000w each, will the total power consuption 4000w right? will it be so high allso if no operation is performed? wish i could give 10000 point for this!!! THX IN ADVANCE! Paolo.
  • oloap88 Aug 03, 2010
    hi,
    i'm planing to install this used ibm BLADE server for a customer.http://www.itsco.de/Server/IBM_Bladecent...
    -it has 14 blades, bu i would like to install a single os using all the processor toghether, like a multi cpu server, since it will be used as a render farm. is it possible or i have to install a single os on each blade?
    -Since it has 14 disks, one on each blade, can they be configured as a unique raid 5? if not is there a way to make a software raid?
  • 4,281 Answers
You can install single os like win 20008 server enterprise edition or other version of it. Configure RAID with raid utility you can see key stokes for enter in raid utility.You can configure all 14 disk like single harddrive with raid configuration. Just use 1 rj 45 jack don't need to connect all rj 45 . 14 blades enough. N o worry about power supply just connect it to power strip in rack connect all cable to serial . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 03, 2010
  • 2 more comments
    are you sure i can configure the in a unique raid5 on that specific modell?
    each of the 14 disks is on a separate blade.
    is there a raid controller into the management module?
    i need to know how high is power consuption, since the studio i'm gonna install the server doesen't have a lot of power avvailable..
    Is it possible anyway to connect each blade trought rj45 port in a teaming like config to increase bandwith?
  • If your motherboard support in bulit hardware raid utility then you can see key stokes for use raid utility when you power up the server.
    But if not then you can configure all harddrive.
    For that you need to go to right click on my computer icon then click on property then click on manage then disk management then right click on all drive 1 by 1 and create dynamic disk then you can use all harddrive as 1 single drive it is software based raid.
    Yes you can get more bandwidth with 1 rj 45 jack but for that you need to create bridge between all lan port .
    i haven't bought it yet, i would like to be sure first...
    i don' know if that motherboard support raid.... it's a blade server, i don't even know if it has motherboard?
    can you help me find it out?
    i would like a raid 5 config, is it possible trought software raid?
  • If you install win 2008 server edition then you can configure any raid configuration in disk management just create dynamic disk of all harddrive which you want to make raid 5 then you can use any raid as you want after installing win 2008 server.most of motherboard supports in built raid so check it in bios first.
I cant intall window 2003 in IBM server x3400 , wher to find the SCSI driver < took me 24 hours and i didnt find it yet anyhelp thx.....
You can install Windows 2003 using IBM Service Guide CD. Its an image file (.iso) . Burn it after download . Then boot from cd and follow the simple wizard . Find the link below
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5088993
Thanks
Nov 15, 2011 | IBM x3400 Server
What is 9u rack
http://en.wikipedia.org/wiki/Rack_unit
9 refers to its height, 9 times bigger than an 1U
Aug 04, 2011 | IBM BladeCenter H Chassis, 9U...
I face the problem (any hard drive is not found) during windows server 2003 installation in IBM x3400 server machine
Welcome to fixya.
You need Ibm Server Guide cd to do this job. Please find the link below
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5079561
Its an image file , so burn it into cd after download .
You can start installation by booting from the cd
Thanks
Please Vote if it is helpful
May 11, 2011 | IBM x3400 Server
IBM BladeCenter HS22 (7870) not boot from cd/dvd
Go into the BIOS and change the boot devices so that the CD/DVD boot first. Also, make sure your server is seeing the correct blade and its devices. (If not check your connections.)
Good Luck
C2Solutions
Feb 24, 2011 | IBM BladeCenter HS22 (7870B4U) Server
Can not install 2003 server in ibm x 236 as it is showing no drives are present
hi,
You should download the IBM ServerGuide software in order to install win 2003 on 236 server.
You can download it from the below link. It's a image file , so after download burn it into cd and boot server from cd and follow the instructions .
http://www-947.ibm.com/support/entry/portal/docdisplay?brand=5000008&lndocid=MIGR-57504
That's all
Thanks
Dec 13, 2010 | IBM x3400 Server
My Ibm Blade HS22 freezes without any error logs is this an known issue
dear rajesh,
is it happend on booting time or on processing time
and give me more info about
which os?
what type of svr app. your using?
no of proc.
any raid ?
Aug 11, 2010 | IBM BladeCenter HS22 (7870B4U) Server
What is a 9 u rack what other sizes of rack do we have
A 9U rack has a front opening that is 40cm high.
1U is 4.45cm.
I have no idea what other sizes you have.
Jan 05, 2010 | IBM BladeCenter H Chassis, 9U...
About ibm server x3400 drivers
You can download the drivers from IBM's website:
http://www.ibm.com/support/us/en/
Aug 31, 2009 | IBM x3400 Server
IBM xSeries 360 Server support Win 2003?
The good news is IBM says it will work, the BIOS might require an upgrade. I would consult ibm.com and get the latest updates for your hardware after that insert CD and reboot!
Have Fun.
Jul 23, 2009 | IBM xSeries 360 Server
Computers & Internet Logo
63 people viewed this question
Alun Cox
David Payne
David Payne
