Question about 3Com 5500G-EI
What is the default password on a 5500G-EI i want to log int into it but i have failed
Why Does User Authentication Fail When the User Logs In to the Switch from the Web System?
The possible causes are as follows:
The user name or password is incorrect.
Run the display local-user command to check whether the user exists.
Run the display local-user username user-name command to check whether the user password is correct.
There is no HTTP user access type.
Run the display local-user username user-name command to check whether the AuthMask field of the user contains H (HTTP login).
The user connected to the switch is full. The switch supports a maximum of five users.
LS S6720S 26Q EI 24S
Nov 08, 2016 | Computers & Internet
How do I log int my gmail accoint if I have forgotten password
Go on to the gmail account log in page and click Need help? Then click I don't know my password. There you will put your email address. Then click continue. There it will ask you some personal questions about you and will direct you to reset your password
Dec 22, 2014 | Computers & Internet
A username and password
WRT320N - Default password is admin. No user. There is a reset in the back if this fails. Hold it in till it cycles to clear custom settings.
2 Wire - No log in credentials by default. There is a reset as well.
Nov 28, 2012 | 2wire 2700HG-B Router (2700HGB)
A505 S6970 Toshiba laptop HDD#1/SDD#1 password
Maybe you mean log on password. If you never enter a password to log on, but suddenly when turning on the computer, you are prompted to enter a password to log on, but always failed. You try to log in using an administrator user but failed. Chances are, the operating system is infected with viruses.
So, the operating system has controlled the virus.
solution:
Install the new operating system (not repair the operating system)
Nov 27, 2011 | Toshiba Satellite A505-S6970 Notebook
Hi, I have two VM citrix servers that i have load balanced using windows NLB. My users are on a different subnet so I have the load balancing configuration set to Multicast mode. (I have a second nic in...
I have not worked with 3Com switches only Cisco, but I thought I would post this as I found it when googling:
multicast routing-enable pim
on the vlan interfaces:
interface Vlan-interfacex
ip address ***.***.***.*** ***.***.***.***
igmp enable
pim dm
Those commands should help you get multicasting to work. notice, Vlan-interfacex means you will have to do it for each Vlan you created. Some switches do not include multicast support in their base models but make you buy additional licenses to enable it. Cisco is like that, not sure about 3Com.
Chris
Sep 08, 2011 | 3Com Switch 5500G-EI (3C17261) Network...
I don t have the password and when I go to the IP address written on the back of the product, the first thing they ask for is the...password!
You can find a download for this routers product manual here:
http://www.dlink.com/products/?tab=3&pid=DIR-655&rev=DIR-655
If you haven't modified the password the default password should be in the manual. If the default password doesn't work, you should be able to hard reset the device by pressing a button on the back with a paperclip and then log in with the default password.
Apr 26, 2011 | D-Link DIR-655 Wireless Router
Cant log on as administrator
Can you log in as:
Administrator
NO PASSWORD
This is the default admin login.
Once you are here you can right click MY COMPUTER and click MANAGE from the context menu.
In the LOCAL USERS AND GROUPS menu... you can open the USERS folder and start re-set your user accounts.
Failing this, get HIRENS... it has a MS password re-setter and you can re-set the admin password and log in.
Mar 26, 2009 | Microsoft Windows XP Home Edition
The switches under 3Com 5500G- EI cannot communicate each other
I don't know anything about them, but here's a 444 page pdf on them. Hopefully it will help:
http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c02583472-1.pdf
Feb 19, 2018 | 3Com 5500G-EI
Internet stopped working and I can't log on to the router, maybe we changed the name and password. Can I reset, and what would be the default name and password?
you may try to reset the router by pushing the little button for 30 seconds at the back of the router..
leave the default name blank, then default password is the word password. if this failed, try putting admin on the name, then 1234 or password on the password box..
hope this should do the trick..
Oct 30, 2008 | Linksys Wireless-G WRT54G Router
3Com 5500G-EI Logo
671 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
john smith
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
