Question about Fujitsu ScanPartner 15C Flatbed Scanner
This is scanner which has been used is now not scanning. Scanner ready green ready light is constantly blinking not going to steady green. Also under scanner no driver is listed.
Fujitsu Scan Parnter 15C.
This is scanner which has been working is not. Scanner green ready light is constantly blinking and not going to steady green. Also under scanner no driver is listed. I've rebooted the PC and turned the scanner on and off. Windows 2000 is on the PC. The scci card under device manager is listing the card as working properly. It must be the scanner itself. The scanner light is on also if that helps trouble shooting.
  • 72 Answers
Open the document feeder and check to see if there are pieces of paper stuck in the rollers.
Posted on Jun 17, 2009
Getting blinking "red light" , doesn't scan
There are a few reasons this might happen. 1) Check if the transport lock is in the locked position. Unlock the unit if it is locked.
2) An error occurred. Try restarting the computer, unplug the scanner, wait 10 seconds and reconnect the scanner. (This fixes issues where the software isn't running/fully loaded or the connection isn't solid).
Try a new USB cable and a different port. If you have a USB hub in the middle, try a direct connection. (Bi-directional communication is needed and this may show as an error if it is lost.)
3) Try unplugging the scanner from power and plugging it back in.
4) Try unplugging the optional accessories. If they fail, the unit may indicate a failure.
5) The lamp may need to be replaced.
6) Something else may have failed. Consider if it is worth having the unit serviced.
I hope one of these ideas helps.
May 16, 2010 | Epson Perfection 3490 PHOTO Flatbed...
SprintScan 4000
paul here i am, what happened, you suddenly ended our session, do you still have the script? we can continue it there if you want. just watch out for my reply.
Jul 30, 2008 | Polaroid SprintScan 4000 Film Scanner
Computer says scanner is ready to go, lights are blinking, but scanner will not scan paper through.
Go under the advanced settings for the scanner and select ADF (Auto-document Feeder)
Normal 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I can give you more information on the specific method for setting this up if you need it, but would need model and make of the scanner.
Apr 13, 2010 | Fujitsu ScanSnap S510
Xerox Documate 252, just quit working
The flashing green light has the following meaning:
• Blinking green: indicates the scanner is waking up from power
saving and preparing to scan.
• Steady green: indicates the scanner is ready to scan.
How to Adjust the Power Save Settings for the DocuMate 252
1. Right-click on the One Touch icon and choose Show
Hardware from the pop-up menu.
You can also click the scanner icon at the top of the One Touch
Button Panel.
If the Hardware View of the panel is open you can also right-
click on the DM252 icon.
The Hardware Properties dialog box opens and shows
information about your Xerox DocuMate 252 scanner.
2. Click the Properties button.
Your scanner has a built-in power saving feature that is set to
power down after 15 minutes of idle time. You can change the
time before the scanner powers down, from 1 minute to a
maximum of 3 hours.
3. Click the arrows for the Lamp timeout setting and choose a
time setting.
To return the scanner to its factory settings, click Reset Device.
4. Click OK to save the changes and close the dialog box.
Let me know if this solves the problem and thank you, Binary Bob
Dec 09, 2008 | Xerox DocuMate 252 Path-Through Scanner
UMAX 2100XL IS CONNECTED, 2 G LIGHTS FLASHING WITH NO PRINTS
OUR SCANNER IS CONNECTED BUT DOES NOT WORKING. DOES NOT POWER ON THE "SCANNING LAMB" NOW THE TWO GREEN LIGHTS ARE FLASHING ( POWER AND READY ) BUT THE SCANNER DOES NOT WORK OR SCAN.
Dec 09, 2008 | Umax PowerLook 2100XL Flatbed Scanner
Hello, I have just acquired a second hand Konica Minolta Dimage Scan Elite 5400. The utility software works fine. However, when switching it on, the green indicator light by the on-off switch does not...
All the comments I've seen made regarding similar symptoms to your were related to the setup of the device. Apparently the device is very finicky and I have heard many people say that the installation process for the scanner has caused a lot of people issues.
From website:
  • Dimage Scan must be executed before turning on the scanner for the first time.
I suspect that the device won't be properly recognised by the system without the software already being installed and configured before the device is attached. I would remove the device, uninstall any trace of it from your system, and try again with a fresh install.
Jul 31, 2008 | Minolta Office Equipment & Supplies
Minolta Dimage multi pro
Initially, I get a green flashing light when unit turned on, but after a minute or so, it turns to a red flashing light. It will take in the film tray only when blinking red, not when blinking green. My iMac has a hard time seeing the scanner, keep getting "scanner not found" messages. I have to go to system profiler and have it refresh and then it finds it, then the scanner software sees it too. But I have been unable to one preview out of it, says LED error and that's it. Using 10.4.10 on an iMac 20" with 2.5gb of RAM, using Pshop CS2 or going through Minolta Driver of OSX I got off of VersionTracker. I did remove the screw for transport right away. Will feed in 35mm tray with red blinking light, will not feed in 120 tray except partially with red blinking light, and only a couple times out of maybe ten tries.
Aug 23, 2007 | Konica Minolta Dimage Scan Multi PRO Film...
Ready/Error Light
IT have just been down to look at our scanner & cleaned the sensor which is in between the rollers just where the paper flits out at the bottom - we now have a green light! So look for that sensor.
Apr 18, 2007 | Panasonic KV-S2046C Pass-Through Scanner
Blinking lights on standby, unable to scan
mi scanner no se puede instalar porque me sale un aviso de que debo tener firmado el software .
como obtengo el controlador para la instalacion en windows vista home basic
Mar 26, 2007 | Acer ScanPrisa 640U Flatbed Scanner
The Scan Dual IV will not initialize on startup although the door is closed.
 Hi I'm GusGusGus, I just posted a solution that might help. It's under the post about "2nd request for help on the scan dual 4", Hope it helps. Good Luck!
Jan 07, 2007 | Konica Minolta Dimage Scan Dual IV Film...
Fujitsu ScanPartner 15C Flatbed Scanner Logo
454 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
