How to configure D-Link DES3020 switch - Computers & Internet
How to upload ready configuration file into the new switch?
yes you can upload configuration file on S5300 switch flash using serial connection. Please check below link. is an upgrade guide for deploying a system software. it shows you how to upload system software to the flash, the process is the same for configuration file.
it is possible to connect a laptop to the switch? Ethernet cable, configure ip addresses, enable ftp, configure ftp user and then upload to file to the switch via ethernet?
Apr 10, 2015 | Huawei Computers & Internet
D link des 800d switch configure ip addess for 2 computers on a network
D-Link DES-1008D 8-Port Ethernet switch is unmanaged switch which can only support 10/100 MBPS.The DES-1008D is a passive switch which means there is no way to configure the ip address and no need to.
Jun 30, 2011 | D-Link DES-1008D 8-Port Ethernet Switch...
I need the master password
If the switch has not been configured leave the username and password blank here is link to dlink support which has the manual and everything you need to know to configure and reset it.
Apr 30, 2011 | D-Link Dlink DES-3028P Switch 24-port...
I wanna password reset my D-link 3624i switch...can anyone help?
Recovering a Lost Password - If the password for the router configuration is lost then the
following procedure can be used to set it to "friend".
1) Power cycle the router
2) Hold down the "s" key during startup. (The router will startup with the
current release but no configuration
3) Edit the configuration file and remove the line (Ctrl Y):
set user=manager pass=3af00c6cad11f7ab5db4467b66ce503eff priv=manager
4) Save the router configuration
5) "restart reboot"
Feb 25, 2011 | D-Link DES-3624I 20 Port (DES-5220TF DEMO)...
Hi, can anyone brief me the steps How to configure the D-Link DES-3026. Dinesh.
This switch is a plug n play device. No need to configure anything for basic use.
If you want to go for advance settings, You can log into the switch via webconsole and then providing the username and passwords you can loin and do the advance configurations like VLAN settings, Speed/Duplex settings, QOS settings etc
Oct 28, 2010 | D-Link Dlink DES-3028P Switch 24-port...
D-Link DES 1024D
There is no configuration on the switch, this is a dumb layer 2 device. Plug in you PC's etc.. and go. The switch will auto detect the speed and duplex of the device connected to it.
Dec 10, 2008 | D-Link DES 3225G Networking Switch
Dlink switch
Lenesh,
What are you trying to do? Switches don't need configuring as much as routers and modems. Tell me more about what you are trying to do.
Thanks
Kevin
May 22, 2008 | D-Link Computers & Internet
Configration
Here is the link to download the user guide (it thoroughly covers configuration) for you Dlink DES 3225G Layer 2 24 port switch in .pdf format (you'll need Adobe reader to use it, and you can download a free version at Adobe's site if you don't have it): Here's the link: http://www.its.bth.se/courses/etc001/DES3225G.pdf
Good Luck.
Feb 25, 2008 | D-Link DES 3225G Networking Switch
Computers & Internet Logo
75 people viewed this question
Alun Cox
David Payne
David Payne
