Question about Insignia Kix MP3 Player
Frozen on Making Playlist
Unable to play any music with this device is stuck on "Making Playist", does not respond to being powered off.
But I am able to access the files via USB.
Any ideas?
  • 4 more comments
  • Anonymous May 11, 2008
    iI turn it on and it says making playlist and nothing happens,i waited but it didn't do anything.I turn it off and back on but it automatically goes to making playlist.
  • Brecshkowsky May 25, 2008
    Exactly what it says there, I can put music on it, or take it off, but as soon as I unplug it from the computer it freezes on the Making playlist screen. What do I do? I didn't try anything so I wouldn't break something.
  • Anonymous Jun 09, 2008
    FROZEN ON MAKING PLAYLIST
  • Anonymous Jun 14, 2008
    Same here did anyone get this fixed?
  • Purple blaze Jul 03, 2008
    well my insignia has a simuler problem but I can not access the files oranything elts for that matter
  • crysann30 Jul 10, 2008
    My MP3 insignia is stuck on, will not play, its just stuck with the light on displaying a full screen like its on pause. I connected it to my computer, but nothing changed. the light is still on and nothing popped up on my PC. I have not opened it to take out the battery, I would rather not do that until I have tried everything else.
When you copy music files from your PC to the Kix and the transfer is complete, do not immediately unplug the Kix from your USB. Instead, leave the Kix plugged in the USB on your puter for at least 10-15 minutes. The Kix will display "OK to disconnect," but just leave it plugged in for a good amount of time AFTER you copy all the files you want. I have found leaving the Kix plugged in for several minutes allows the play list to be created and not get stuck.
Posted on Aug 07, 2010
Just called Insignia at 800.699.9218 and they had a fix. You will lose all data on the player when you do this, so transfer what you need off of the player first.
Basically, you just Format the player. Put the player in your computer, find the icon for it, right-click, select Format. Do a full (not quick) Format. Pull it out, see it it gets past the frozen screen.
This seems to have worked for me; have only tested briefly but seems OK.
Posted on Aug 29, 2008
  • Mike Weyrauch
    Mike Weyrauch Jul 28, 2012
    that worked!!!! thanks!!
Same Problem here
Posted on May 13, 2008
Hi, did you get your problem solved? I just bought it today, and had the exact problem.
Posted on May 04, 2008
On my Gogear Raga 2GB I can't make a playlist. (SA2RGA02). With WMP I can synchronise the music, but there's no playlist on the device. All the music is stored in different folders on the Raga and not in...
Sync all the songs you want onto the raga via 'songbird'.
Stay connected, then go to windows explorer, identify your device. Then in 'Music', make folders for your playlists. Manually transfer (drop and drag) your songs to the required folder/playlist.
When using the raga use the 'folder' option. Works as playlists.
grayza
Jul 10, 2010 | Philips GOGEAR SA6045 MP3 Player
I can't make my archos
be sure that you have already saved a list of song on your playlist. and for the pdf also make sure that there was a file that save on that location...
let me know
Aug 29, 2008 | Archos Audio Players & Recorders
Stuck on making playlist
im having some problems whit my insignia kix player it is stuck on making playlist an will not move can you help me email me at hackjamel@yahoo.com
Jul 21, 2009 | Insignia Kix MP3 Player
Need Creative Zen user manual. No longer on the website. I really just need to know how to create playlists if you can help me with that.
  • Creating playlists for Creative Zen MP3 player
  1. Step 1 Turn your Creative Zen MP3 Player on and add music to its hard drive if you haven't already. Without music on your player, you won’t be able to select tracks for a playlist.
  2. Step 2 Select "Music Library" from the Main Menu. The Main Menu should appear as the first menu when you turn your device on.
  3. Step 3 Select "Now Playing" from the options available, then press the Options button.
  4. Step 4 Select "Save as Playlist" from the list of options. This will save the tracks you have listed currently as a playlist that can be reloaded later.
  5. Step 5 To play a playlist back, go to the Main Menu, select the playlist and click
Jun 16, 2009 | Audio Players & Recorders
Unable to play playlists on my Hitachi MP3
You can try dragging the playlist into the folder that you open up when you connect the player and then you want to drag and drop music. Then drag the folder and drop into the music folder which means you are copying from the player to another folder on the player. This manages to solve the problem of the player re-arranging files alphabetically and may help your playlist issues.
Jan 28, 2009 | Hitachi DMP-7 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
No response
Ok, What we need to do is do a simple test. First hold the power button for 15-20 seconds, then hold the centre enter button for 15-20 seconds. Keep doing this and it should reset!
Apr 05, 2008 | Apple iPod nano 3rd Generation
Ipod wont respond/frozen thingy
try resetting to defaults and then updating to the latest software then download your music after that.
Jan 30, 2008 | Apple iPod MA446LL/A MP3 Player
Playing music from playlist
Either you uploaded a .Wav file or another file that is not supported.
Check the file and make sure it is a midi or mp3
Jan 09, 2008 | Samsung SPH-M500 Cellular Phone
Open Questions:
Insignia Kix MP3 Player Logo
329 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
