Question about Toshiba Satellite P105-S6104 Notebook
My mouse is stuck in one place i have rebooted my pc and unplugged my mouse but still nothing
  • 808 Answers
Reset CMOS will fix will fix ur problem if not do reginout Best of luck
Posted on Aug 03, 2010
Cursor freezing
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it.
Remove the trackball inside the mouse.
Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring.
Clean the outside of the mouse with rubbing alcohol and a cotton ball.
For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth.
Solve Hardware Problems
Make sure the mouse is connected properly.
The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction.
Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer.
Connect the mouse to another computer, then reboot the PC.
If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system.
Also, try a different mouse on your computer.
If there is no PC freeze, your mouse is probably malfunctioning.
Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub.
Connect the mouse directly to one of the USB ports on your PC.
Try different ports until you find one that works.
Replace the batteries.
If you have a wireless mouse, replace the batteries with fresh ones.
Also, try using a different kind of mouse pad.
Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse.
Install more RAM or memory.
If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs.
Installing more RAM will help your PC run more efficiently.
Solve Software Problems
Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse.
Remove any new hardware and drivers you may have installed, then reboot the computer.
Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System."
Select the "Device Manager" tab, then scroll to and select your mouse.
Uninstall any drivers that are listed.
Unplug the mouse and reboot the PC.
Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted.
Remove viruses.
PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours.
Also make sure the virus definitions are updated regularly.
Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze.
Go to "Control Panel," then click "Display," and then "Change Display Settings."
Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot.
Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
I switched on my laptop this morning & my mouse is moving all over the screen, not letting me control it. I manage to run CCleaner (found nothing) but before I could run MalwareBytes it was off again....
Not knowing what model of laptop you have makes this difficult. I doubt if this is a virus but a fault within the mouse pad. You will need to enter the bios by either tapping the delete key or F2 keys while booting. This should get you into the bios. Look through the menus until you find the onboard mouse and disable it. Reboot with a usb mouse plugged in and this should work. now go into the control panel and system then hardware and remove the entry for the mouse. reboot with the mouse unplugged and windows should redetect your mousepad and reinstall its drivers. All should be well if the mousepad is not the fault.
May 04, 2011 | Computers & Internet
I UNPLUGGED MY CORDLESS KEYBOARD AND MOUSE FROM THE COMPUTER AND PLUGGED IT BACK IN, THE KEYBOARD WORKS AND THE MOUSE DOESNT. IT WAS WORKING FINE BEFORE
It is not uncommon for the system to lose track of an input device.
Most of the time reseating of the input in the connector is sufficient. However there are time when you have to reboot.
Place the keyboard and mouse in the places you want in the computer's ports, and reboot.
good luck and don't forget to vote!!!
Sep 28, 2010 | Logitech Cordless Mouse
Mouse not responding
Clean the PC Mouse
1. Unplug the mouse, turn it over, then twist the retaining ring counter clockwise to remove it. Remove the trackball inside the mouse.
2.Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in alcohol. Replace the trackball then secure it with the retaining ring.
3.Clean the outside of the mouse with rubbing alcohol and a cotton ball. Use a small amount on one area at a time. For an optical mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth.
Fix PC Mouse Problems
1.Plug the mouse back in. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins, then carefully plug it in making sure the connection is secure. Reboot the computer, and then test the mouse.
2.Connect the mouse to another computer. After the mouse is connected to a different computer, reboot the system, and then test the mouse. If your mouse works on another computer, the problem is most likely with your PC or operating system
3.Check for device conflicts. When you install another device on your computer it can sometimes cause conflicts with a PC mouse. Remove any new hardware and drivers you may have installed then reboot the computer.
4.Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Driver" tab then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse then reboot the PC. Reboot the system again, plug the mouse back in, then allow Windows to reinstall the drivers if prompted.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 19, 2010 | Computers & Internet
Hello! My PC crashed once, and i can't reboot it. It aborts while " initializing usb.. " directly after starting. (Win7)
if there are any external HDD attached unplug them before you boot.. try that first...if that doesn't work,..reboot..then press F12 or F2 ( you might have to tap-tap to get into settings ) to go into bios settings. disable boot from usb and make sure that the boot setup starts with the cd-rom first then the HDD 2nd and nothing 3rd.and if that fails... hopefully you made a back up/repair disc. use that...9/10 times it will fix what the problem is.
Jan 26, 2010 | ASUS P5PL2 Motherboard
Mouse don't work after restored
Reboot. The puter should see it and install it
Oct 07, 2009 | Computers & Internet
My compaq is stuck on the compaq logo screen
hi there..
turn of your computer before you do anything ....
unplug all the cables.. i mean everything..
then we are going to a proceedure called as powercycle..
after unplugging all the cables..
press and hold the power button for 5 - 10 secs..
or you could leave the computer for 30 secs.. without connecting the cable..
connect only the basic cables. .such ... keyboard. mouse. monitor.. cpu and restart your computer..
this should work
if not please do let me know ..
Aug 20, 2009 | Computers & Internet
Computer freezes on boot up
make sure the mouse and keyboard are in right connections...if you look closely youll see icons next to ports.
try without mouse at first start up ,load windows and use key with windows logo on it to access start and scroll to shutdown tab and restart...plug in the mouse before restart.
if logo tab isnt assigned press ctrl + esc to access start menu.
Oct 23, 2008 | Acer Aspire 5670 Notebook
Toshiba Satellite P105-S6104 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
