Question about Sharp Actius AL3D (PC-AL3DU) PC Notebook
I restored the hard drive to original state, and nothing comes up. it says an nv4- nvidia file is missing. i dont have a back-up cd. Please advise. it wont start in safe mode.
    Problem Solver:
  • 10 Answers
I would suggest you go to the Nvidia website and get the correct driver for your hardware. Then can you start Windows setup in repair or recovery mode and add the driver to the hardware list?
Posted on Aug 03, 2010
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
How to Fix NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
    Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
  5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
  6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
  7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
  8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
    Try replacing the IDE cable cable if you suspect it might be faulty.
  9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
  10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
  11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will
Jan 22, 2014 | Belkin Basic Wireless Router
I want to restore my HP Compaq 58 to its original state so I went to the Update and restore in the Computer settings then pressed Restore. After that I opted for Delete all and restore Windows. The problem...
The first option is to restore to factory settings (as purchased when new. This option deletes your personal files, and just re-installs to factory. If using this, it is advisable to find any discs to programs installed since original factory state (as of time of purchase) It is advisable to use a program like Balearic Adviser to collect information, and sometimes your keys to any programs you instaled , and cannot find the software to reinstall.
The second option appears to be to wipe the hard drive so that your data is not available to others if you wanted to sell/scrap (recycle) your pc. The data is often saved on a seperate partition on your hard drieve
Nov 18, 2013 | Computers & Internet
OS Hard drive missing
Using Recovery Partition
The Recovery Partition quickly restores your Notebook PC's software to its original working state. Before using the Recovery Partition, copy your data files (such as Outlook PST files) to USB storage devices or to a network drive and make note of any customized configuration settings (such as network settings).
About the Recovery Partition
The Recovery Partition is a reserved space on your hard disk drive used to restore the operating system, drivers, and utilities installed on your Notebook PC at the factory.
Sep 12, 2013 | ASUS Computers & Internet
I cannot get the screen to come on, it is just black but the laptop is on
try removing the battery from th back.wait for like 5 minutes then restart the computer.
else try pressing F8 at the startup if you can go yo the advance boot options.
go to repair my computer..select the language then select the username and password..then in system reco ery optios try startup repair or system restore.
else go to safe mode with networking...there in command prompt type sfc /scannow if you have vista or 7..else if you have the xp in advance boot menu try last know good configuration.
Try the below steps to start the recovery
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
if the above step is not working try to use the windows repair with the oprating system cd.
insert the cd in to thr cd rom, restart the computer
press F12 at the startup it will give you the boot sequence then select the cd
and if none of the things are working contact Toshiba..there might be a hardware issue
plese rate if you find this helpful..thanks
Sep 01, 2011 | Toshiba Computers & Internet
Hello. I flashed the computers bios to upgrade the computer and now the restore disk I got with my system is out dated and older then the computers bios that was flashed. It loads and restores the...
You did not post the make and model number of the computer. There may be a proprietary driver missing. the BIOS should have nothing to do with the issue. On another note, XP is no longer supported so it may not be able to register with Microsoft.
Mar 03, 2017 | Viscom V2 Premier 17'' LCD Computer...
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
CAUTION:
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
The problem of my hp pavilion dv5 is this, i want my laptop to be back on its original state so i tried system restore. i have my recovery discs aside from the built-in recovery partition. i inserted the...
You have formatted the hard drive (containing Boot Manager) using recovery disk 1.
That's why the error message.
Just insert disk 1 again.
Shut down the computer (press & hold the power button for a minute).
Restart.
Follow the instructions that come up.
If it doesn't help, reseat the hard drive. (open the back cover, take out hard drive, reconnect it)
Also you may go to BIOS (tap F1 while booting) and set the cd-drive as the first boot device.
Hope it helps.
Nov 06, 2010 | HP Pavilion dv5-1000us Notebook PC
Dell dimension e520 reinstalling the XP Media center
connect your hard drive to other computer and then have it clean by scanning with antivirus. and then copy the important files on it to the working computer. after copying the files thats the time to return back the original hardrive to the dell dimension and then reformat and reinstall the system again again. please use original operating from dell or what ever is applicable.
mlenavz
Jan 31, 2009 | Dell Dimension E520 PC Desktop
Windows could not start because the following fio valiant 671dp
Contact the makers of your laptop and order the recover disk. They go around $40.00 to $50.00 dollars.
Dec 28, 2008 | KDS Valiant 671DP Notebook
Question about my hard drive
LOL , no my friend , you simply lost your HAL.dll , hardware abstraction layer
you need to reinstall windows , thats the easy way out
or you can take the hard road to china and attempt to recopy your HAL.dll to the proper location on the drive , my personaly I don't even go there , a fresh copy of windows is so much better in these instances because you don't know what else has gone wrong at this point , best to do a reinstall
because there really is nothing like a good ole fresh load of the operating system.
take the puppy back to school like it was at the factory baby :->
shalom
Aug 05, 2008 | Maxtor Hard Drive
Sharp Actius AL3D (PC-AL3DU) PC Notebook Logo
37 people viewed this question
Top Sharp Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
