Question about RCA RCR412C Remote Control
I can not find the code for my universal remote control
This are the numbers that I find in the remote is rcr311w and r55n7 and 5807p
I have the codes but does not work with the codes that they have in the list
  • 11 more comments
  • Anonymous May 06, 2008
    HELP
  • Anonymous May 17, 2008
    codes
  • raylew May 21, 2008
    I have a R55N7. ID# RCR311W. Nothing works as described. This model is not even included at the www.rca.com/codefinder site. RCA doesn't include it----WHY? Can anyone make this model work?
  • ks1980 Jun 02, 2008
    yeah. i bought this cheap rca universal remote at wal-mart, and looked for it at the rca site, and they don't even list it. tried all the codes for the brand tv i'm using it for, and it doesn't work. the remote responded exactly like it was supposed to to the codes, but none of the functions worked.
  • Bristagirl Jun 06, 2008
    I, too, purchased an inexpensive remote at Wal-Mart. When trying to use the web-site for access the codes, my remote's code (R55N7) isn't even listed as a choice!
  • Christy M Jun 12, 2008
    I have a RCR312W universal rca remote and a Durabrand TV. I can't get the TV to work with the remote and the TV is stuck on video.
  • Anonymous Jun 16, 2008
    I was able to get my Panasonic TV programmed using the following method. However, I have a cheap Curtis DVD that the code search could not find.
    On my remote, the ON-OFF button does not illuminate. It's the red led that turns on and flashes when the play button is pressed.
    To program a component using the Automatic Code Search method, perform the following steps:
    Turn on the component you want the remote control to operate.
    Press and release the component button that corresponds to the component you want the remote control to operate.
    The illuminated ON-OFF button turns on and remains on.
    Press and hold both the component and ON-OFF buttons.
    The illuminated ON-OFF button turns off.
    After the illuminated ON-OFF button turns back on, release both buttons.
    The illuminated ON-OFF button remains on.
    If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained.
    Press and release the PLAY button.
    If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off.
    Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
    When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
    If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
    To save the new code, press and release the STOP button.
    The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
    If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s functions.
  • Anonymous Jun 23, 2008
    I DID BUY AT WALMART THE THREE WAY RCA REMOTE CONTROL,IT WORKS WITH THE TV,BUT SUCKS ON THE DVD!AND IF YOU TRY TO FIND THE CODES THRU THE INTERNET THRU THE WEB SITES YOU ARE WELCOMING A RIP-OFF !
  • rod9243 Jul 10, 2008
    This rca universal remote from walmart lights up like it is suppose to but it's not finding the code for an advent tv I have. None of the functions are operating the tv in any way.
  • Anonymous Oct 26, 2008
    icant find the code
  • Anonymous Dec 05, 2008
    cant program remote for magnavox tv/dvd.i have remote rcr312w and it iis not listed
  • Anonymous Dec 10, 2008
    it wont let me change the chanl with out the romote code
  • sam66_45068 Mar 27, 2009
    I have an Orion TV that I need a code for. Can anyone help me? I have an RCR311W universal remote.
Press desired component press and hold on/off and component desired ... hit on off till it turns compponent off ... hit stop to save
Posted on Jan 18, 2009
Broksonic TV I am asking for the right number.
Posted on Oct 31, 2008
I have a flat screen 19 inch sylvania tv.i have tried the universal remote control rcr312w and i have tried alot of codes ,dont seem to work .
Posted on Sep 19, 2008
Its ****
Posted on Jun 29, 2008
    Scholar:
  • 186 Answers
I think on this remote there is a setting you can enter where you can press the power button over and over until you find a matching code that works. Check your manual for something like this. Sometimes it will work for a tv with a code not listed.
Posted on Apr 25, 2008
I found the solution in finding the code of my 52" zenith big screen t.v. programing it of rca remote control. used the manual script that came with remote that I bought at Walmart and did the AUTO CODE SEARCH AND ENTRY and also programmed my dvd with it.
Posted on Oct 14, 2008
I think that Audiovox and RCA are owned by the same company. I went to the Audiovox website and clicked on RCA accessories to find my remote. Also rcaaccessories.com may work.
Posted on Jun 14, 2008
I need the code for a rca remote (rcr311w) for a zenith TV
I am very happy to help you reprogram your RCA RCR311W for your Zenith TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up on this remotes device code list.
I hope that helps.
Mar 07, 2010 | RCA 3-dev Universal Remote Remote Control
I dont know code button for my remote rcr311w
Your best bet is too look at the manual for the remote or to contact the company for further instruction.
Oct 26, 2009 | RCA Universal Remote Control
Codes for Daewoo tv on an RCR311w
You can try codes: 1004, 1005, 1006, 1016, 1017, 1082, 1171, or 1190.
Find these codes and others for RCA remotes here:
http://remotefinder.rca.com/default.aspx?site=rca
Apr 07, 2009 | Universal Remote Control DIRECTV Universal...
I NEED CODE I HAVE A VIZIO TV AND A RCA RCR311W Universal Remote Control
Go to www.vizio.com/support.  They have all the codes posted by model number.
Jan 24, 2009 | RCA Universal Remote Control
Need tv code for phillips model # pl5120 c121 for rcr311w i cant adjust color
There are a few codes you can try for the Philips TVs:
1002, 1003, 1004, 1008, 1012, 1019, 1062, 1068, 1069, 1075, 1076, 1087, 1219, 1238
To look up these and codes for other TVs, go here:
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Jul 19, 2008 | Universal Remote Control DIRECTV Universal...
RCA RCR311W Universal Remote Code for LXI TV
From what I can tell, it could be any of these codes:
1000
1006
1048
1049
1062
1072
1073
1100
1109
1130
1162
1181
1203
1212
1233
I used this website:
http://tv.rca.com/RCATV/NewTV/Templates/GenericSupport.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2ftechnicalsupport%2ehtml&NRNODEGUID=%7bCDBA69CE-8CEA-435A-8F62-C5E6DBE1ACF6%7d&NRCACHEHINT=NoModifyGuest#
Jun 12, 2008 | RCA Universal Remote Control
Not finding the correct codes for my tv
Here's a link to the manual. On page 7 you'll find instructions on how to do a code search. This will usually find a code set that will work.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c8bf9d533cdd50c488d29f828467b8b1&q=RCA+RCR311W
Jan 12, 2008 | Universal Remote Control DIRECTV Universal...
RCA RCR412C Remote Control Logo
3,482 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
