Question about Bemis 1200 Slow Elongated Toilet Seat, Bone
Hinge broken seat/cover in champagne colour - Bemis 1200 Slow Elongated Toilet Seat, Bone
  • 43,501 Answers
The hinges are not repairable or replaceable...
Replace the whole seat...
heatman101
Posted on Aug 05, 2010
The toilet seat has come half off. How do I fix it?
you can get replacement screws at home depot or lowes if the hinge is broken you need to replace the seat
Jul 14, 2012 | Duravit Metro Toilet Seat and Cover
There is a broken hinge to raise and lower the back rest on my driver side seat . How does that get repaired? Does the entire seat have to be removed from the car? Or is there another way to make the...
you will have to remove the seat and the cover to access the hinge, it may just be welded. If it cant be fixed, maybe find one in a salvage yard, If its not the right color, the covers will need to be changed.
Sep 09, 2011 | 1999 Plymouth Grand Voyager
Lexmark 7600 printer cover is not seating properly after installing printer cartridge
The two hinges are attached to the back of the printer by two screws. I removed the two screws and lifted the top off, freeing the two hinges (the one on the right was broken so part of it stayed in the printer). There is a restraining line on the right side that keeps the top from coming completely free of the printer, but it can be worked around while still attached. I removed the broken pieces and the internal spring from the right side hing. The spring is what was keeping the top from seating correctly. I assume you could order a new hing, but I reassembled the printer without the spring and the top seated properly. The printer works, but I will now need to be very careful when replacing the ink cartridges because of the missing hing on the right side.
May 10, 2011 | Lexmark International Lexmark 7600 Series
The hinges of Duravit toilet cover seat 006331 are broken. Where can I get replacements?
I have not been able to find a "tribeca" on the Duravit website but on the site of one of their parts distributors I found the Duravit Toilet Seat DUR 006331000. Is this your model? Starck 3
On the Duravit website this product looks very similar but not the same number.
I was not able to find replacement hinges for this model sold separately. You might consider using their Find a Retailer feature to find an outlet close to you where you might make inquiries or order hinges and/or a new lid.
Jan 17, 2011 | Duravit Tribeca US-Type Elongated Toilet...
Have a Duravit Starck 3 2-piece toilet 2105010000 Hinges that hold the seat and cover are broken. Where are these hinges available?
Unfortunately you won't find a universal replacement part to work with this seat which you would commonly find at your local hardware store. I've looked through the Durovit site and could not find a parts catalog. Try using the find retailer option on the manufacturers site and if there isn't a retailer in your area contact the manufacturer directly to see if they supply parts for their seats. I'm guessing they don't and you would likely have to purchase a new seat.
http://www.duravit.com/service/find-a-retailer-useo6suuk8.html
Duravit USA, Inc.
2205 Northmont Parkway
Suite 200
Duluth, GA 30096
Phone +1 770 931 3575
Toll free: 888 387 2848
Fax +1 770 931 8454
Toll free: 888 387 2843
info@usa.duravit.com
Aug 02, 2010 | Duravit 0063810000 Stark 3 Toilet Seat and...
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Jun 15, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Dec 22, 2008 | Toto Aquia II Dual Flush Toilet
Bemis 1200 Slow Elongated Toilet Seat, Bone Logo
179 people viewed this question
Top Bemis Home Experts
john h
ray gallant
jdtech
Are you a Bemis Home Expert? Answer questions, earn points and help others
