Durabrand DBDVR01 dvd/video recorder combi
We have dissconected it and then reconnected it to a diffrent tv and now it says " turn off power, interface error " We tried it back on the old tv and says the same. Put video in to see what happened and now that is stuck too.
  • plcpete Aug 25, 2008
    my dbdvr01 also gives the same error message. but i can still do programmed timer recordings if i get into the timer set prog before the error message shows. it then records to dvd ok, but i have to use a different player for playback. i am still trying to find the solution to this problem.
    from petershowarth@hotmail.co.uk
Durabrand model dbdvr01 power supply problem. r106 open circuit,q101 short circuit,d102 short circuit,ic101 blown up,suspect r108a and r100a faulty. ROY
Posted on Sep 16, 2010
Set up problem
Does this Durabrand combo player actually have an RF output? Almost every unit I've seen today only has audio/video out. No RF out, no tuner for recording. They're meant to work with the TV's AV inputs and some line input source for recording (if it's a recorder at all). There may just be no RF for you to be tuning to.
If the player does in fact have RF out and you can't see it on either channel 3 or 4, take it back to the retailer if you can or contact the service number in the manual. It would have to be a defective unit.
Apr 03, 2009 | Durabrand Televison & Video
Black screen
Did it used to work? If it did then I would say it may be.
If it is new, the Durabrand DVD players default to the component video out (RCA jack). If it is hooked up with an S-Video cable you will need to connect it with the RCA cable and then go to the settings and change the signal out to S-Video and then reconnect it with the S-Video cable.
Also make sure that the correct video source is selected on the TV.
Cheers
Dec 31, 2008 | Durabrand DVD-1002 DVD Player
Tv and dvd combi
There is no switch [TV\DVD] ?
Usually, when u turn off the TV, it should goto DEFAULT, which would be the TV. Do u have an antenna connected to the TV. Some TV go blank [deaf & dumb] when there is no signal to TV. If you cannot get the TV portion on, then I would suggest the u have an electronic switch [DVD is off, it will goto tv] that is shorted in DVD position. Is there a button that has no markings ?[you know, rubbed off by touching it so much]
touch EVERY button two times [one for on, and one for off] except the ON\OFF button !!
May 12, 2008 | Televison & Video
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Recording Problems
Hi.
Yes.
Most tv sets with freeview built in do not allow you to record it.
Check your tv instruction manual to see if it is at all possible.
http://dysonmanuals.llc.nu/
Chris..
Feb 09, 2008 | Televison & Video
Durabrand dvd/video combi
There could be at least two ways to hook in your VCR. The common way is to hook your VCR inline (between) the sat box output (RF or antenna) and the TV RF/antenna input. This will allow you to play the VCR/DVD & record whatever channel the sat box is set to. I'm not real familiar with the newer sat boxes, but I assume they output one channel at a time, thus, you can only record that channel. On the older cable or outdoor antenna systems, you could record one channel while watching another. Perhaps some sat boxes have this capability. You might do a Google search with the box Model number to see if an online manual can be found. The other hookup possibility is if your TV set has audio/video inputs & outputs. Hook these to the matching input/output of the VCR/DVD.
Sep 30, 2007 | Televison & Video
No sound on TV
If you do not get result you can purchase one video rf converter. Rf converter contains one video input in yellow colour and two audio in red and white colour and one cable connector as outout. Connect dvd output to this converter and tune the program in which place you receive dvd signal.
Sep 16, 2007 | Durabrand DWT1905 TV
Televison & Video Logo
662 people viewed this question
Top Televison & Video Experts
Electro Med Services...
