Question about Texas Instruments TI-89 Calculator
Darken screen!!! Im having a problem with my TI-89 titanium. Each time i power up my calc a black screen will appear bt it has having all the icons appearing faintly when i tilt it towards the lights. The contrast buttons wont work. I even changed the batteries bt still having problem...Plz help me out, got examz coming!!!
  • 16 Answers
Reset your calc, press 2nd left right on simultaneously. it should work.
Posted on Jul 09, 2008
The screen on my TI-89 Titanium turned blue after replacing batteries? How do I fix this? It turns on and off but does not respond to any other buttons.
If you cannot see anything on the screen, you may need to adjust the graphing TI 89 Titanium calculator contrast :
1.To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark.
2. To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light.
Sep 01, 2012 | Texas Instruments TI-89 Calculator
My TI-89 Titanium is stuck on the main screen and no matter what button i press nothing happens. I have tried changing out all of the batteries and nothing is working.
Hi
when you turn on the Calc press the 2nd button and if the busy indicator is on its and hardware problem or if none of the keys is working
let me know if you want to fix
ecrdn@yahoo.com
Jack
Jun 26, 2011 | Texas Instruments TI-89 Calculator
I have a TI 89 but when I turn it on the screen is totaly black after waiting like 10minutes or so it started to brighten.
Try adjusting the screen contrast. Turn the calculator on. Press and hold the diamond key, then press + to darken or - to lighten the screen.
Jan 12, 2011 | Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
My ti-89 screen is frozen and wont accept input
Remove the batteries and wait a minute or two. Put them back in and turn the calc back on and it should function normally. Check for stuck buttons as well, as sometimes they will cause the calc to appear "frozen".
Sep 30, 2010 | Texas Instruments TI-89 Calculator
How do i find a online calculator like a texas instrument I NEED ONE
You can downlod the TIEmu from this site Install it on your computer and you can run it any time you want. It can emulate the TI 89 Titanium, the TI92Plus, as well as the TI Voyage 200PLT. You need to download also the GTK 2.6 library which you have to install on your computer.
It needs TI OS's , which you can download from the TI Website as you would for a real calculator. To emulate any of the 3 calculators, download the revelvant OS.
When you run the Emulator for the fist time, point it to the location of the TI OS for the machine and it will import the files to make images.
After you learn how to use it, you will be able to switch between calculators. I do not like the emulator for the TI89 Titanium because I have a 14 inch laptop screen, but the Ti92 run at twice the size is just perfect.
If you are not familiar with the calculators above, you can download the Virtual TI (version 2.5). It emulates the TI83Plus. It is available at ticalc.org
Hope it helps.
Thank you for using FixYa.
Nov 12, 2009 | Texas Instruments TI-89 Calculator
When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Sep 22, 2009 | Texas Instruments TI-89 Calculator
TI-89 Titanium (hardcore reset)?
Hey guys,
Do this it will reset your calc and get you out of your busy state
2nd - left arrow - right arrow - on
It will reset your calc no matter how frozen it is.
Nov 16, 2007 | Texas Instruments TI-89 Calculator
Half of screen blank
it may have been spoilt, TI-89 Titanium calculators are not very lasting. You may want to try the resetting all memory (2nd 6 F1 3 Enter)
Oct 17, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
303 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
