Question about Thomson 21DC320 21" TV
Procedure to change the internal seting of tunning
    Problem Solver:
  • 14 Answers
Try searching the net for your tv's service mode on how to enter or access it.
Posted on Aug 03, 2010
Factory setings
RECORD on PAPER CURRENT Printer SETTINGS AS will be lost.
IP address used FAX Settings and what ever you use.
http://www.lib.ucdavis.edu/ul/services/mfd-3300-printing.pdf
Found this procedure on internet
http://www.ehow.com/how_7376251_reset-canon-ip-3330-printer.html
Mar 14, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How do i reset my sunsui 19 inch hdmi tv to factory seting because I'm getting a cloudy signal
To reset it to its factory settings, you have to enter its service mode option. Do not change any values there if there is not necessity. Select the factory mode option only. To get more details about how to enter the service mode,http://electronicshelponline.blogspot.com/ check this link. It has details about how to enter and exit service mode. After entering the service mode, and have done the settings, it is a must get out from it, by using the exit option. All procedures are given there in detail. Pull up older posts there, by the sites' left side bar.
Jun 07, 2013 | Sansui 19 in. LCD TV
I want to change language of my ibm netvista desktop
The IBM Netvista should have options to change the language settings built in if you read the manual but generally, if you follow these instructions it usually works.
Go to the BIOS utility and change the language:
To run the Setup Utility program, use the following procedure.
1. Shut down the computer and wait for all lights go off.
2. Start the computer.
3. When the Setup Utility prompt appears on the screen during start-up, press F1. A Setup Utility menu will appear.
4. Follow the instructions on the screen.
5. When finished, select System Summary to verify that any configuration changes have been accepted.
Feb 06, 2013 | IBM NetVista PC Desktop
Power Switch comes on but moniter goes back to sleep.
use external monitor to setup internal monitor setings
Nov 10, 2012 | eMachines T3508 PC Desktop
Getting limited or no internet connectivity. reset ip stack and winsock, still no dice
there is something wrong with the lan or tcpip settings.set a menual tcpip v4 ip from the property of connection then open the router setting page.there will be tcpip setting or lan setting "all routers have diferent interfaces for seting " or find dhcp somware.set dhcp as server mode and rang from 192.168.1.2------------------>192.168.1.64.all router have not same ip seting in some router 192.168.0.2------------------->192.168.0.64.when you set dhcp sever mode these seting will automatically done.but if you want to increase your limit then use given example.
tell me your router model so i can tell you step by step procedure
Jul 11, 2011 | Computers & Internet
I have an LG KG375 mobile phone. I have just changed carriers and want to change the speed dial #1 voicemail number. How do I do this please?
This No. Change in your massage setings option,
go to to massage option and then enter the setings and change your voicemailbox no.
Feb 27, 2010 | LG KG375 Cellular Phone
I just bought a vintage Gucci 3800L chronograph watch, and I cannot change the date. How do I do that?
pull the seting knob half way of seting time and scroll up and down to change calendar
Jan 20, 2010 | Watches
Ansmann classic sirius 12 esc problem
Follow this start up procedure. 1) Switch on transmitter 2) Connect battery to ESC 3) Squeeze throttle fully (on handcontroller) 4) Extend throttle fully.
Oct 26, 2009 | Toys
F4:2398
enter in setings->restore factory setings->tipe the password and then click ok->the phone will be reseted on setings.Thanks
Nov 12, 2008 | Sony Ericsson K550i Cellular Phone
Configuration setting does not save
make the changes on the printer,
save the changes (press twice on setup button).
chek if the driver have "use driver setings"
if you want to use the setings from the printer, you need to change the "use drivers setings" to "use printer setings ( this is to change on the driver)
Apr 10, 2008 | Zebra Z4M Printer
Thomson 21DC320 21" TV Logo
51 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
