Simpson Espirit water not Filling
Have a Simpson Espirit 700. When using cold water the washing machine takes about an hour to fill because the water just dribbles out.
If using hot water the speed at which the unit fills is fine. Have check water taps and pipes all ok.
  • 171 Answers
Try removing your cold water hose and check to see if the screen filter has a calcium buildup or some other obstruction.  if not that then possible bas inlet valve on washer.
Posted on Aug 03, 2010
My eziset 950 is dripping internally (Simpson washing machine)Is there a fix for this problem .thanks
if you mean dripping from where the water comes out when filling,the problem is the cold water valve needs replacing
Jul 20, 2018 | Washing Machines
My Simpson eziset 8.5kg washing machine has just stopped filling with cold water
Then either the cold water inlet valve is faulty or the main board is not supplying power to turn valve on. Use a multi meter to test which it is or get someone out that can.
Apr 10, 2018 | Simpson Washing Machines
Washing machine, Simpson Espirit 500, won't start at all. Power is on and water, cold turned on as well.
Possibly the door switch isn't working or is maladjusted so the machine's brain thinks the door is still open.
Feb 18, 2017 | Simpson Washing Machines
My washing machine Simpson Model no 22S711 wont turn off when it is filling up with water
if it stops when you turn the machine off the problem will be that the pressure switch chamber is blocked unblock it should be ok
Sep 30, 2012 | Simpson Washing Machines
Simpson espirit 750 manual required can't change water level
Hello
Try these links to download the manual to your machine.
laundry.manualsonline.com/ex/product/.../m/simpson/d/.../22S750M
http://www.dataentryjobs.us/67948.html
trd-techconnect.net/User's%20guide,%20Instructions%20book
www.search-document.com/pdf/.../simpson-esprit-washingmachine
www.sign.ac.uk/pdf/sign97.pdf
Feb 09, 2012 | Simpson Esprit 750 Top Load 7.5kg
I have a Simpson Espirit 6.5 kg front loader. Model 45 S 651 D. The washer takes a long time to fill with water and the soap container is not washing out. I believe it might be the Cold Water Inlet...
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 01, 2011 | Washing Machines
My simpson espirit 700 has been in storage for
check first the continuity of the power cable. next is the fuse if it is not busted. then try to open the control portion there might be some coroded contacts.
Apr 07, 2009 | Washing Machines
Washing Machines Logo
218 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
