The tv says "factory" and will not let me change channels
    Problem Solver:
  • 14 Answers
Try replacing the eeprom with the same tv.
Posted on Aug 03, 2010
Devant LCD TV: channel always set to a certain channel (ex. channel 2) with out signal upon re-plugging or turning TV "ON". Is there a default channel setting? how to? thanks!
Do a hard reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 27, 2017 | Televison & Video
I do not have the remote to my Hitachi TV and need to change the channel to get picture. How do I manually change the channel if the screen is black.
Look on the TV for buttons for power, volume up and down, channel up and down and menu.You can get a new factory remote from here :
Jan 22, 2017 | Hitachi Televison & Video
Can not get off channel 3 can not get other channels want change
Hi is the remote control faulty, ? Have you tried changing batteries? If this is not the issue have you the facility of changing channels manually? If you can and this has no effect try a hard reset to factory default through the remote control menus. If the fault is not hardware related this shuld rectify the tv.
Jun 12, 2015 | Hisense TC24FS2H TV
Sharp LC-32SH130K always goes back to same Channel
go to the menu option and restart your TV settings to the factory settings. If you event can not use the menu and same thing happens, there is something wrong with the remote; maybe a button is being pressed all the time or there is some conductive material stick to the electric board.
Feb 04, 2014 | Sharp LC-32SB21U 32 in. LCD TV
I have an Emerson LC320EM8A tv. I am able to turn the tv on either by the remote or at the unit. After about 15 min, the tv changes changes the channel to Video1. I can change the channel back to...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Apr 10, 2017 | Emerson LC320EM8 32 in. LCD TV
Menu Setup Timer Channel changes back to 001
The TV should not change the channel by itself unless you disconnect it and even then it would have to be disconnected for a very long time. Try reseting the TV to its original factory settings.
Nov 28, 2011 | Polaroid FLM-3232 Television
When I turn on the tv, Get a blank screen with
Unplug it,replug it back an hour later,the tv should set back to the factory setting.
Mar 22, 2010 | Toshiba 22LV505 22 in. LCD TV
Factory on screen at startup then goesto Fac and remains there
open ur backcover go to the front bottom ur remote controls panel take it apart clean it.
take ur remote control apart too change batteries,a good cleaning
Aug 15, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sansui Model no SAN 5452, text on screen
i think , there shoud be an option as (factory mode ---- on/off) in system , if true then modify it first.
if not true check all features in the menu for several times . other wise finally notedown the tv model number and buy a service modes for colour telivision , i think this boook is published by bpb. and search in that book for that tv model . adjust the service codes as there ...
if not available that book please mail me.
Oct 26, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
