Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I have an Epson TX100, which has worked well until now. I recently had to install another printer, which didn't work properly, so have uninstalled it. I have changed the Epson default back to show that it's selected as the default printer and it has a tick on it. The printer will not work when Print is selected on the pc, but the scanner does work. Cannot decipher what is wrong. Help plese.
  • 124 Answers
Go to Control Panel - select Printerss - right click on your printer - click on Remove Printer - reboot - printer drivers should reinstall automatically.
Posted on Aug 03, 2010
I lost my disc to install epson tx100 in my laptop. how can i install it?
Here is the link for the Epson TX100 printer driver:
https://www.yousendit.com/download/MzZGOGNRTXZTRTd2Wmc9PQ
Here is the link for the Epson TX100 scanner driver and Epson Scan utility:
https://www.yousendit.com/download/MzZGOGNTTk16NE5FQlE9PQ
Feb 07, 2011 | Computers & Internet
I have an epson stylus TX100 and its not working @ windows 7
I found Epson drivers for Win 7 at their web site (Australian version):
http://tech.epson.com.au/downloads/category.asp?sCategory=Multi_Functional&id=StylusTX100&EmailAdd=&CanEmail=&SelOS=Y&MetricIDReturned=3429820&sCategory1=Multi_Functional
Pick your version of the OS and click through (I had to go through a couple of pages).
If you initially installed a generic Win7 driver or an older version of the Epson driver, you may want to uninstall the driver and start again with the USB cable not connected to the computer.
I hope this helps.
(the site I started at:
http://www.epson.com.au/Products/multifunctional/Stylus%20TX100.asp )
Feb 19, 2010 | Epson Office Equipment & Supplies
Why my tx100 printer can't work with vista
ISSUE : Epson Stylus TX100 is not working with VISTA Computer
Environment :
Printer : Epson Stylus TX100
Computer Operating system : VISTA
Analysis : According my understanding your printer use to work with different operating system like XP Home /Prof. etc But it is not working with VISTA
SOLUTION :
Cause of your problem might be : Software issue
To get the print out of printer your computer need to have a driver software on it. You can check the compatibility information written on the CD / DISK itself
Else you can also download the Compatible drivers from the following link of EPSON
http://www.epson.com.ph/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=4&pid=1373
or you can simply open www.epson.com
and click on Drivers and Support and select the printer -- you can easily download the drivers ...
I Hope it will solve your issue
Jan 02, 2010 | Epson Office Equipment & Supplies
Epson TX100 stops after scanning
download Epson resetter http://tricks-collections.com/software-epson-resetter-t10-and-tx100/
then reset the ink counter. that should remove the general error warning.
Nov 06, 2009 | Audio Players & Recorders
All in one epson stylus tx100 installer
You can find the necessary drivers that you'll need for the TX100 on Epson's website. I've included the link for you below. Hope it helps!
TX100
Sep 29, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I have tried to uninstall epson TX100 printer from my computer by using add & remove programs but this does not work . How can I get it off my computer?
only System Restore can remove that programs inside in your Computer. When that options in the Control Panel is also necessary to uninstall & remove by using that Printer Utility Disk to be inserted into your PC. That Disc will help you to remove the Printer.
Epson Stylus TX100 printer Woeks but scanner not
It is a scanner as well, but you have to access the scanner through the software that came with it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 27, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Tx100 does not recognize my ink!
there is a chip re-setter located just above the cartridges. it is actually a small button switch. if that does not work, try to remove the cartridges. just lift them (1 by 1) slightly then put it back again
Aug 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
77 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
