Question about Dishwashers
Should the water cover the heating element? or does it just make the water hot as the water is sprayed about? david
  • oldtwit Apr 26, 2008
    it does NOT answer my question!! oldtwit
    Genius:
  • 1,073 Answers
You got it
Posted on Apr 25, 2008
I'm getting hot water for 2 minutes , then it gets cold
Most electric hot water heaters have two thermostats, one near the top of the tank and one near the bottom, and are covered by removable metal cover plates. The thermostats are pressed firmly against the bare metal wall of the hot water heaters tank.
The top thermostat usually has a high limit switch that will trip if the water gets too hot. When it trips it shuts off the electricity to both the upper and lower heating elements.
To reset the high limit switch there is usually a red button that you must press. When the upper limit switch trips it is often an indication that something else has gone wrong with the heater.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
Hope this helps out
Feb 02, 2011 | General Electric GE SmartWater Household...
Much of our plastic ware, such as leftover containers, and pots and pans come out with a white dusty covering on them. We have hard water down here, but I ususally run the cycle with a glub-glub of white...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 12, 2011 | GE Dishwashers
Even though I turned up the thermostat on my hot water heater, the water in the dishwasher does not seem to be hot enough. Mold is growing in the food grinder and even though I choose the heat dry option,...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 25, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Can I use cold water fill when installing this machine
No,
There are only a few dishwashers that have good enough heating elements to be able to use cold water.... most all of them need to fill with hot water and then the element just keeps the water hot...
heatman101
Oct 10, 2010 | Dishwashers
Run times are long and water is not getting hot
heatman101
256re
Apr 14, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
No hot water
Check your panel breaker to make sure its on. If it is, it's possible that the upper thermostat or element has burned out in your heater.
First remove the upper thermostat cover plate and check the high limit switch button. If it has tripped, press it to reset it.
Check for power at the input terminals of the upper thermostat. (usually marked L2 and L2) If no power is present then check your circuit breakers or wiring to the water heater.
If there is no hot water then the upper thermostat should be applying power to the upper heating element. Check for voltage at the upper heating element. If there is power at the heating element but the element is not getting hot then the heating element needs to be replaced.
If there is no power at the upper heating element then the upper thermostat needs to be replaced.
Hope this helps.
Mar 14, 2010 | Welding Tools
Dishwaher water does not get hot enough
heatman101
iueyj
May 06, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    Hotpoint hda3700g00bb water not heating
    heatman101
    e1
    Jan 27, 2009 | Hotpoint 23 in. BFI68 Built-in Dishwasher
    Dishwasher
    Wash water isn't hot even after we run hot water in sink before turning on dish water. However rinse water is hot. It appears the heating element is not working on wash but is on rinse?
    Dec 19, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
    Dishwashers Logo
    27 people viewed this question
    Top Dishwashers Experts
