Trying to set firewall to block certain ip ranges but cannot get it working - Thomson 585 v7. ie I do not want to accept connections from 208.75.123.0/24
  • 55 Answers
You should try mac adress filter, that will do the job.
Posted on Oct 31, 2010
How to connect my MSSQL server through VPN by using PPTP
192.168.1.X is a local ip address ,, i trust that thhe vpn is in seperate places and is done with the wan ip over an internet connection?????
OK maybe the problem isnt on your side but the main office building,, when connecting , have someone looked for repeated attemps to connect by observing the fire wall,, if it appears to be blocked byu the firewall simply diasable any and try it out.. If it works then all you need to do is set the firewall correctly..
I was reading the ip address in your original post and those are local address,s are you certin the VPN is correct ???? did you use the correct STATIC IP ADDRESS ASSIGNED BY YOUR ISP??
Jan 20, 2008 | Cyberguard SG300 (00852503000366) Firewall
Need driver thomson tg 585 v7
visit free download ptf.com/thomson/thomson+tg+585+v7+free+driver -
Feb 15, 2010 | Computers & Internet
Lost connection
what u need to do is go to the interface of ur thomson speed touch through writing the ip address of that modem on the address bar of ur internet browser then go in that setup....Choose router instead of bridge.
Jul 14, 2009 | Computers & Internet
Non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
Jul 02, 2009 | Thomson RCA DCM245R Modem
Open NAT with Thomson (Speedtouch) TG585 v7 Router
First, try adding a wireless card to the Xbox, run the wireless off of the router OR if you have multiple connections (broadband, should be an "In" port, and several "Out" ports) Try connecting your PC and you Xbox through the "Out" ports, with the cable modem cord hooked into the "In" port...
Feb 02, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
1)i cant connect to the interface of Thomson 585 v7... 2)i cant connect to the internet...it says that my pc cant get an ip
if you cant get an ip best thing o try is to look at the bottom right of the screen on the task bar click on the two computers thing click on the support tab and repair ip if that dont work calling your internet provider would be best bet they might be having issues
Dec 04, 2008 | Computers & Internet
Thomson router
dsl signal / light on modem ..ok
connection to computer ..ok
able to log-in to the internet service provider ..ok
check your IP address setting on the computer, must be set to automatically get IP address, same goes for the DNS setting.
Oct 04, 2008 | Computers & Internet
Thomson TG 585 v7 Wireless Problem
HI
The following info. might help you fixing the above problem:
For WIRELESS CONNECTION follow these Steps:
(Note: Keep the Ethernet cable plugged in unless we set up
WIRELESS)
1: Click on Home Network
2: Wlan
Click on Configure which is the 3rd last icon on the Top
Make sure that the option-Interface Enabled is ticked.
Channel selection should be ob Manuall.
Wireless channel can be 11( thats what is in my case).
Encryption is again depending on what type of sercurity you wants. I would suggest go for WPA.
After editing the above info. do not fail to note the KEY before clicking Apply
Now just enable the WIRELESS CONNECTION on your PC /
Laptop,
Pull the SSID of your router and Click connect.
It will ask for the WEP/WPA key?
Enter the key and Click connect.
Sep 11, 2008 | Computers & Internet
Problem with IP Surveillance configuration
Can you view the stream in IE or IP surveillence or is it that you hit the camera in IE, the sign in box shows up (cause you put in a pasword), you put in the password, and it cannot connect and says retry.
Possible problems.....
The IP you are typing in is really not the IP of the camera (comes from the box being checked that says 'reset the IP on reboot') Use the installation Wizard to find the camera and it's IP.
Your firewall is blocking the stream. Try disabling it and reconnecting.
Your cameras IP is not in the range of the DHCP server of the router it's connected to. Review your router's DHCP list to see if the camera IP is in that range.
The password on the camera is corrupt. You will need to hard reset the camera and reset it back up from scratch to connect.
Worst comes to worse, you can always just hard reset the camera and start over.
Apr 05, 2008 | D-Link DCS-3220 Network Camera
Computers & Internet Logo
100 people viewed this question
Alun Cox
David Payne
David Payne
