What is the correct cartridge for garrard 6 200 cp turn table
  • 3 Answers
Posted on Apr 26, 2011
I have a Denon D-F10 component system and I have bought a Garrard SP Mk 3 record player which is the best cartridge to use in the Garrard for this system?
All depends on how young you are and just how good your hearing is. If you have hearing issues or are aged and have a high frequency rolloff (normal for age) there is no point in paying megabucks for what you cannot hear. Just be pragmatic and get a cartridge that sounds good to you and is gentle with your records because it has high compliance and tracks at low tracking forces. Shure M91ED is a great cartridge and still available if you get lucky.
Aug 30, 2017 | Denon Audio Players & Recorders
What needle do I need for Garrard turntable model 3250? My needle is missing because of my son discarding it.
If you look at the cartridge it fits into. Then you will see a model type and number. Enter that into Google and the stylus will also turn up.
Feb 11, 2017 | Audio Players & Recorders
The centre small spindle and the longer one which can stack 7 records on my Garrard 6-300 are missing. Where can I buy them? I need a cartridge too. Which would be the most suitable one? Thanks.
http://www.turntablebasics.com/index.html
This site should have them if you have a look around.
You can fit any cartridge you want, as long as it will go on the headshell. But most can be adapted to fit. It depends on how much money you want to spend on the cartridge. In this case the more expensive is probably the highest quality.
Nov 10, 2016 | Audio Players & Recorders
10.92.03 error showing while printer door closed.
One of the cartridges may not be seated correctly. Open the door and remove all the cartridges. Close the door and power the printer on. Then, replace each toner one at a time, closing the door in between each one. This should allow you to determine which toner is not seated correctly. Remove and reseat that cartridge. Clear any foreign debris from the area. You may have to replace that cartridge in the event it is defective.
Nov 11, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
I inherited a Garrard Synchro-lab 72B that I want to use to play 78 rpm records. I also bought a Shure M78S cartridge with the required 2.5-mil stylus. however when I started to work on replacing the...
Sometimes you have to invert a changer and place on padded supports to get access to cartridge. Be sure to identify wire connections to the old cartridge before removal and keep track of cartridge mounting hardware so it doesn't get lost.
May 12, 2017 | Audio Players & Recorders
Background hum from speakers when turntable is turned on. Turntable is a Garrard Zero 100 and receiver is JVC RX 318. Hum is on even with no Lp on the table and is much louder if I wave my hand over the...
You need tro ground the Zero 100 to the amp frame. Also, you may want to reverse the plug in the outlet, if that is an option (Try to plug the turntable into the amp if possible) Keep trying different arrangements until you minimize the hummmmmm
Where the heck did you find a Garrard Zero 100? That turn table is at least 35 years old ... I have one, BTW and that is how I solved mu 60 cycle hummmmmm
I hope this helps you
Positive comments welcome
Thanks for using FixYa.com
a
Oct 28, 2009 | Audio Players & Recorders
I need a new needle for my Garrard 40B turntable
contact this company and ask them if they have the correct replacement or a suitable equivalent?
mailto:info@needledoctor.com
Jun 04, 2009 | Audio Players & Recorders
Garrard turntable model 630s
There are a couple of things that need to be done here and there is no guarantee that the unit will work, but I have been successful in the past.
First remove the platter and clean all of the grease out of the unit. With all of hte grease removed, replace the platter and make sure that it turns freely. Regrease the unit one all of the old is removed. Next you will need to clean and treat the rubber drive wheel.
Good luck,
DAn
Mar 21, 2009 | Teac AG-V1050 Receiver
Canon thermal printer cp-330
search for canon cp-220. There is an explanation of the problem. Good luck.
Nov 27, 2007 | Canon CP-330 Thermal Photo Printer
320 people viewed this question
 Grubhead
Grubhead
