Question about Sharp Heating & Cooling
Code 14 is displayed on my air conditioning unit AY-X08BE
  • 503 Answers
Check the door panel for the explanation of the error code. But you can still try this to fix the problem,
Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in. see if this fix the problem.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Aug 13, 2010
    Genius:
  • 1,478 Answers
panel.
button.
Take care.
Posted on Aug 03, 2010
  • hayman411 Aug 03, 2010
    SORRY BUT THERE IS ONLY ONE AUX BUTTON ON THE FRONT PANEL NO CODE ERROR DESCRIPTIONS. YOUR SUGGESTION HAS NOT APPEARED TO SOLVE THE PROBLEM. CAN YOU HELP ME FURTHER PLEASE?
Sharp AY-XP 12 ER indoor inverter showing -0 14 error
Sharp AY-XP 12 ER indoor inverter showing -0 13 error
Sep 11, 2013 | Sharp Heating & Cooling
Tip
LG UNIVERSAL SPLIT AIR CONDITIONING FAULT COEDS Error Indicator: # The...
Error Indicator:
# The function provides self-diagnosis and displays an error code if there is any trouble.
# Error codes are displayed on the Indoor unit's Wired Remote as CH**, and/or Fascia Display. In
addition, the code is indicated via LED's on the outdoor unit control board.
# If more than two troubles occur simultaneously, the lower number of error code is displayed first.
# After an error occurs, if error is released, error LED is also released simultaneously
for more check the link bellow
http://electro-medical.blogspot.in/
on May 10, 2015 | LG Heating & Cooling
After spraying off the unit the display shows e1
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Jul 12, 2011 | Haier ESA3125 Wall/Window Air Conditioner
AMANA ACB087R, reading E1 on display and none of the buttons work at this time. Someone please help me solve this problem. Thanks.
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
heatman101
Sep 06, 2010 | Amana Heating & Cooling
My airconditioner displays E1 and turns off after only 3 minutes of use, what's happening?
heatman101
Sep 03, 2010 | Sharp Comfort Touch AF-R120EX Air...
My HEC window airconditioner is displaying an E1 code what is that and what can I do?
http://www.fixya.com/support/r5620902-e_1_code_window_air_conditioning_units
heatman101
Aug 23, 2010 | Haier Heating & Cooling
E 1 error on display ?
heatman101
Aug 19, 2010 | Danby DAC9003D Air Conditioner
Error code 34... eventually error code 14
How to fix error codes 14 &34 on Carrier Infinity furnace
Mar 30, 2009 | Heating & Cooling
Air Conditioner Error code?
Error "FL" is coming It is not going by applying suggesstion in your booklet kindly enlighten
Mar 16, 2009 | Haier Energy Star ESA3183 Air Conditioner
1988 new yorker atc trouble codes
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles 14 MAP sensor voltage too low 15 No vehicle speed sensor signal
Dec 20, 2008 | 1988 Chrysler New Yorker
Heating & Cooling Logo
289 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
