Question about Philips 50P8341 50" Rear Projection Television
The green and red color are seperated. how do i figure out which bulb it is or how to fix it myself..
  • Philips Master
  • 8,457 Answers
Not the tv projection lamp problems.The tv have a convergence problems,it dead.Any colors are separated R,G,B.The tv convergence board parts are dead,the 2 STK convergence ICS are dead and some or all it resitors are too.Must replaced all these parts to solved the convergence problems.U have tools and can do soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy ur tv make and model a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Posted on Aug 03, 2010
  • Philips Master
  • 8,617 Answers
Thats a convergence issue. you will need to replace the two Convergence IC and quite possibly a few of the 6.8 ohm resistors. You can get the phillipd DPTV305-DPTV345 convergence repair kit from www.tvrepairworld.com the kit works for your model also and it includes the ICs and resistors plus the CD with detailed repair instructions.
The set has a bowed appearance and the 3 colors have seperated. I imagine the bulb(s) are going as it's a old set.
The arching of color can be adjusted on the color gun by slighty turning the screw on the gun Blue, Green, Red. This fixes the arching and or fade-blinking in and out of color. The gun on my 65" sony is inthe front of the set. Removing the front panel grants me access to this. You may have to access it from the back on your model. Looks like a small box with 3 screws ont he front. Hope that helps...
Jun 30, 2010 | Mitsubishi WS-55807 TV
My tv color is very red and orange but all 3 color bulbs are working it seems... the actual picture only comes through the red and green... help!!!
go to tvrepairkits.com and order the kit that replaces the fluid in the blue and green bulbs, will clear up your color issues no problem :) i just fixed mine, now it looks great.
May 10, 2010 | Philips 55PP9352 55" Projection Television
I need schematic for 450 signal bridge
Each side of the 450 signal bridge has 3 connections....one common to both one lights green light the other the red You need to connect the red and green wires to a 153C contactor the pressure switch that changes the light colors as the train passes. The side of the 153C that has 2 terminals is for the red and green bulb wires. The single terminal and the third terminal on the 450 get connected to 12V fixed voltage. Repeat the process for the second track and contactor. This is the simple mode of wiring a signal bridge or any of the single change the color signals...153,163,353 and 452 single signal; bridge.
Feb 22, 2010 | Toys
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Hitachi 51f510 Color problem
for testing, place the green crt board on the red crt and see if the red crt lights up and the green does not. If the green does not light up then check for 200+ volts on the collector or the output transistor. if you have that kind of voltage thee then check for an open resistor. If not then make sure the transistor is not shorted
Dec 28, 2008 | Hitachi 51F510 51" Rear Projection...
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
Color
yes those ICs will work in your model. You can get replacement ICs and free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Sep 06, 2008 | Apex Digital GB43HD09 43" Rear Projection...
Arched picture at bottom seperating the green and red
Your tv has a convergance failure. the convergance ic's need to be replaced. Upgraded part # STK392-150 or STK392-160. Both ic's should be replaced to prevent future failure of other colors.
May 20, 2007 | Toshiba 43H70 43" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
105 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
