Question about Microsoft MT-SYTPT3227AB 32 in. LCD TV
How do I mount my Soyo MT-SYTPT3227ABMS on the wall
    President:
  • 1,099 Answers
Mounting an LCD (Liquid Crystal Display) TV on the wall may seem a bit overwhelming at first; but it's not that difficult. With a few simple tools, a proper mounting kit and a helper, the job will be a breeze. With a little bit of patience and an hour or two, your LCD TV will look great. Follow these steps to learn how to mount an LCD TV on the wall.
Things You'll Need:
LCD TV
Mounting kit
Tools
Step 1
Find the best spot on the wall to mount the LCD screen. Think about how much room you may want on that wall, especially if you plan on mounting speakers, too. You could hang a poster or picture relative to the size of the television on the wall to see if you like the placement.
Step 2
Pick a mounting kit. You can purchase mounting kits online (see Resources below) along with many other sites. Look to make sure the kit and TV are VESA compatible so that you have standard measurements and quick, easy attachment during the mounting process.
Step 3
You may already have tools needed to mount the TV. You'll need a set of screwdrivers, a socket set, a saw capable of cutting into drywall, a drill and a measuring tape. Having a stud finder with a built-in level is also great to pinpoint the exact location of the stud. The stud finder will be useful if you'll be running wires through the wall.
Step 4
Get the location for the TV picked out. Check near the bottom of the wall to see if the area you plan on using to run the wires is free of obstructions. Using the stud finder for this will make it easy.
Step 5
Find the studs. You should use at least one stud when mounting the LCD screen to make sure that the mounting bolts are driven into something solid that will support the weight of the TV and the mounting bracket. Using two studs is ideal for mounting larger TV's, those with screens larger than 37 inches. Use a pencil to mark the drill holes for the anchors and stud location.
Step 6
Secure the mounting rails to the back of the LCD screen. Double check them for proper fit. Make sure that they're hidden behind the body of the television for a finished look.
Step 7
Cut the hole for the wires to come through by using a drywall saw. The easiest way is to pull them out at the electrical box. This avoids having to go into the basement, closet or otherwise. You can purchase a wall box at your local home improvement store to place in the exit hole of the wires.
Step 8
Drill the holes for the bolt anchors in the locations that you measured and marked previously. Place the bolt anchors into the holes and tap them in with a hammer.
Step 9
Secure the wall mount to the wall. You'll need a socket wrench to ensure that the mounting bolts get snugged down tightly to the anchors. Use a level to make sure you've done an even job.
Step 10
Grab a friend or family member to help you lift the LCD screen onto the mount. Make sure it's locked down tightly and the screen is set to go.
Hope this helps and Good luck
Posted on Aug 03, 2010
  • Sanyade Akinwale
    Sanyade Akinwale Aug 03, 2010
    Also note that there are things to consider in mounting lcd on wall.
    When considering an LCD TV wall mount take these 5 things into consideration.
    1. Size of TV - When purchasing a wall mount, one of the first things you will see is that there are different wall mounts for different size TVs. There is a huge difference in size and weight in a 22 inch LCD compared to a 50 inch model. Mounting hardware will provide more support for bigger TVs such as connecting them to multiple studs instead of just one. The brackets for fastening to the TV will also obviously differ from a large TV to a small one.
    2. Type of wall - Flat panels can be mounted on various types of wall. The most common type of wall is one with wood studding. You will need a stud finder in order to locate the center of the studs which you will mount your TV to. Another common mounting option is to mount the TV to a solid concrete wall or a cinder block wall. In order to install on these walls you will need to use concrete anchors for a secure connection. Most wall mounts will include the proper fastening hardware.
    3. Type of LCD TV wall mount - There are many types of wall mounts to choose from.
    o A fixed wall mount does not have the bells and whistles of the other types. Once your TV is mounted you will not be able to move it at all so take extra care in making sure the TV is exactly where you want it to go.
    o A tilting mount provides some extra flexibility by allowing you to tilt the TV up or down to ensure a proper viewing angle. Generally a tilting mount will rotate up about 5 degrees and down about 15 degrees. This is a good choice for many large screen flat panels often times found in a home theater or family room.
    o Another option is an arm mount. These are more common for smaller LCDs as opposed to big screens. These will allow your TV to be flat against the wall or will allow them to swing out a foot or more from the wall in order to view it from a variety of locations and angles. Many arm mounts will also allow the TV to swivel or tilt as well and are sometimes referred to as articulating arm mounts.
    o For the ultimate in wall mounts you can consider a motorized wall mount. They allow virtual silent operation allowing you to rotate the TV for an optimum viewing angle with the touch of a remote button. These can certainly provide a "wow" factor for your home theater.
    4. Cable management - You will want to make sure you plan on how your TV will be connected to the rest of your home theater components. Some people simply install molding in order to hide the wires, while most people will install a wall plate that allows the connectors to be run through the wall to ensure a clean clutter free look. Be aware of the proper electrical code and consult an electrician if necessary. Power cords should not be run through the walls and most times a receptacle will be installed behind the TV in order to provide power to the TV. HDMI cables have simplified things by allowing both audio and HD video signals through one cable, but make sure to also consider adding component and composite connections as well since it is much easier to do it now rather then adding them later. Many LCD TV wall mounts will have cable management options built in to them for added convenience.
    5. Where to mount your LCD flat panel - Finally you will need to figure out where to mount your TV. The location will be dependent upon your room environment as some people choose to mount above things in the room such as a fireplace. It is generally agreed that for an optimal viewing experience you should mount the center of the TV slightly above eye level of your viewing position. Also keep in mind to leave enough room for your center speaker and front speakers of your sound system.
    A clean install of a high quality LCD wall mount will be a welcome addition to your home and a great way to showcase that new LCD flat panel.
    Good luck....
Where can I get an extending, swiveling TV wall bracket for my SOYO TV model# MT-SYTPT3727ABMS?
Fixya is unable to determine sources for wall brackets applicable to your Soyo TV.
Mar 25, 2018 | Soyo Televison & Video
How to change out the 3 HDMI ports on my Soyo flat screen TV model # mt-sytpt3227abms.
You would have to replace the tuner board or maybe just good reflow
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Sep 29, 2015 | Soyo Televison & Video
Remote code for model #MT-SYTPT3227ABMS
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Mar 01, 2014 | Soyo Televison & Video
What wall mount fits a Soyo TV...MT-PRTPT3208NB
Contact the authorized dealer for Soyo. They can provide you details.
Jul 01, 2013 | Televison & Video
Remote code for the Soyo Model # MT-SYTPT4218AB What's your problem?
These are setup codes for Sanyo: 0049 0097 0110 0004 0268 0012 0108 0180
Oct 25, 2012 | Soyo SYTPT4218AB LCD TV
Soyo tv Mode MT-SYTPT3227AB will not turn on
It might be the power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/783/soyo-mt-sytpt3227ab-power-supply-board-repair-service-no-power-shutdown-etc
Jul 11, 2012 | Soyo SYTPT3227AB 32 in. LCD TV
I have SOYO MT-+SYTPT3227AB TV and cannot locate mounting holes to wall mount the TV.
This TV is not Wall Mountable as the Control Box protrudes and is therefore not suitable for a VESA Wall Mount.
Jun 10, 2011 | Soyo Televison & Video
What screw do I remove from the back on my soyo 32" to mount ??
the screws are already removed the should be plugs little ccircles on the back to remove for a wall mount if not check the tv manual
May 12, 2009 | Soyo DYLT032D 32 in. LCD Television
I need to remove tv stand from my Soyo DYLT032D to mount on wall, Also what screws do you remove in back of TV? Thanks...
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
May 09, 2009 | Soyo DYLT032D 32 in. LCD Television
Microsoft MT-SYTPT3227AB 32 in. LCD TV Logo
429 people viewed this question
Top Microsoft Televison & Video Experts
richie46
Are you a Microsoft Televison and Video Expert? Answer questions, earn points and help others
