Question about Whirlpool Refrigerators
I have a whirlpool sidekick. Love it, but water is leaking from the bottom. About a cup a day I find on the floor. The water is located under the vegetable tray and drains out when it gets too full under the tray.. help.. what do I do. It is ruining my wood floor..
catriver
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Posted on Dec 22, 2006
Sea Breeze
  • 4655 Answers
SOURCE: I have water (condensation?) leaking from under the freezer
I appoligize for not seeing your post sooner here are some links to pages that may be helpful, Let me know if you need more help as Fixya has a problem notifing me of anyones response to a solution , Thanks, Sea Breeze
appliancepartsse@yahoo.com
864-812-1887
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://appliancejunk.com/forums/index.php?topic=22.0
PART NUMBER AND MODEL SEARCH FEATURE
Please feel free to contact me the charge is free, Sea Breeze
Posted on Jul 16, 2009
outdoorsman5
  • 631 Answers
SOURCE: Water frozen in the bottom of freezer on double door Maytag frig.
Shut the water off for one before it ruins all your floor. It probably has frozen and broken a line or the valve. You can go to this site and get a drawing on your fridge and parts if you need them.
http://www.appliancepartspros.com/partsearch/
Posted on Jul 28, 2009
smuschanow
  • 20 Answers
SOURCE: WATER LEAKING IN BOTTOM OF REFRIGERATOR UNDER VEGETABLE KEEPER
This sounds like the problem I responded to for another user. I hope it works for you. I got this when the J-trap on the back of the fridge was blocked, not allowing condensation to properly drain into the drain pan.
I solved this problem by pulling the black drain tube off the J-trap (you may need to loosen the holding clamp at the bottom of the tube), giving the J-trap (it's about 2" round) a slight twist to release it from the sheet metal, and carefully pulling it out. Be careful as the sheet metal is sharp. You will see a 1" PVC tube end that fits inside the J-trap. This must be inside the trap when reassembling.
Flush out the J-trap and reassemble.
Posted on Nov 25, 2009
SOURCE: I have a model ET8CHKXKQ0 1 Whirlpool refrigerator
The drain in the freezer is clogging. When the defrost switches on, the backed-up ice thaws and starts dripping down into the fridge area.
Easiest is probably to turn off the fridge, let it thaw, then check the freezer drain to see if you can unclog it.
Otherwise, you have to pull out the bottom and back parts in the freezer (which will probably have some sort of ice frozen to them). Once you see the drain pan, get a turkey baster and flat head screw driver. You'll have to make a hole in the ice above the drain and squirt hot water until you hear it start draining. The drain hole is off center to the right in the drain pan.
Good luck
Posted on Oct 30, 2010
Large amount of water in wash tub under the wash basket in Whirlpool frontload duet
Even the new duets do have a panel. You need to lay on the floor to see 3 screws under the front. A torx bit will be needed to remove the screws. Before working on any appliance unplug it so you don't get zapped.
However, the problem is likely caused by the door being twisted. This can often be cured by twisting the door so the bottom is making a better seal against the gasket. This is assuming there is not tear or cut on the door bellows (gasket). Water tracks can normally be seen from the location of the leak. Liquid detergents change the surface tension of water an let it flow from smaller leaks so you may need to keep watch while the unit is being used.
Sep 02, 2014 | Washing Machines
Water leaks out on the floor from Kenmore refrigerator mdl 253.7482240h
Be sure the drain line is clear from the bottom of the freezer to the drain pan.
Feb 01, 2014 | Whirlpool ET1MHKXM Top Freezer...
Water leak from under door
When your refer defrosts a couple times a day it produces about a quarter of a cup of water each time.This occurs in the freezer section.The water travels down a drain pipe (or tube) that leads to a drian pan in the bottom of the unit. It is collected and evaporates from the heat of the motor.
If the drain is plugged water will form inside the unit itself.If the drain tube has somehow moved and not allowing the water to collect in the drain pan it will go on the floor.Either way,if the drain is the problem the amount of water should be pretty small, no more than a cup or two.If you have an icemaker or ice and water through the door and the amount of water on the floor is more than a cup or two. I would find the water shutoff for the supply line(probably behind the unit in newer homes)and turn it off.Clean up the water and wait a day.If the water goes away assume that one of the plastic lines in the unit that carries water to the icemaker or door is leaking.If the water continues I would suspect the drain.The only way to check the drain is to unplug the unit and remove the cardboard back,locate the drain pan and see if water is present and that the drain line is in it's proper place.
If one of the water lines is leaking you will most likely need a service tech.
Also it's best to turn the icemaker off by lifting the arm or switch before you turn the water off for testing.
Mar 18, 2010 | Hotpoint HSS25GFP Side by Side...
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
Hotpoint. Water is leaking from behind light bulb
The drain hose in the back of your freezer is frozen shut. The water you see is coming from the defrost cycle. Turn off the refrigerator. Remove the floor from your freezer and remove/thaw all of the ice. Locate the drain in the back of the freezer. It may be behind the back panel. Thaw the drain until water flows freely through it. Reassemble the freezer, and you are back in business.
Oct 22, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Mar 01, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
The water and icecube dispenser constantly leaks water on floor
Needs new solinoid valve. Usually located on the back bottom of refrigerator
Jan 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
WATER RUNNING OUT FROM UNDER REFRIGERATOR
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
Dec 20, 2008 | Whirlpool 19.8 cu. ft. Side-by-Side...
GE Profile TFX27PF/TFT27PF Refridgerator
There is a line from the defroster catch pan, up under the freezer, to an evaporation pan, down under the bottom. If it becomes clogged with dirt, bugs, whatever, the catch pan will overflow, and leave a puddle on the floor. Find it and unclog it.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking Whirlpool refrigerator
My Whirlpool fridge had water droplets falling onto all three shelves and pooling unter the crisper drawers. I solved the problem by clearing the ice-clogged drain in the freezer.
In Whirlpool model ET21UM, the condensation drain hole is located directly behind the freezer. To access the drain hole, remove all your frozen items and place them in a large picnic cooler. Notice that the floor of the freezer is basically a large plastic tray fastened by two small bolts. Unscrew the bolts with a wrench or ratchet and remove the plastic tray. At this point you will probably see that water has seeped under the tray and created a mini ice rink on the bottom of your freezer. You can tap the ice lightly with the handle of a screwdriver to break it up. Once it's broken, toss the ice into your sink, or put it in a plastic bag and store into your cooler to keep everything cold.
Once the ice has been removed from the freezer floor, you should be able to see a metal drip trough in the back under a false wall hiding the condenser coils. It's a little tougher to remove the ice from the drip trough with the screwdriver method, so you might want to use a hair dryer. After a few minutes with the hair dryer, you should be able to remove most of the ice by hand. You can remove any water with a sponge or turkey baster. The only ice left will be a plug of ice in the drain hole in the middle of the drip trough. Heat up a cup of water in the microwave and carefully pour it into the drip trough. If the drip trough is hard to access, you might need to use a funnel. The hot water should melt most of the ice in the drain hole. If it pools in the drip trough and doesn't drain, use a sponge or turkey baster to remove the water and add hot water again. A small length of wire or a pipe cleaner might help clear any other obstruction in the drain hole. When the drain is clear you should hear water flowing through it. Dry off the floor of the freezer and return the plastic floor tray to it's spot and fasten with the two bolts. Remove any water that has pooled in your refigerator and you're done.
Dec 27, 2007 | Refrigerators
Refrigerators Logo
127 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
