Question about EliteGroup P4M800-M7 Motherboard
Computer turns off and restarts again during the operation repeately.
This problem did occured right after I installed this board. I was advised maybe bad caps. I got this checked but there no bad cap showing. They replaced anyway some caps to be sure, put the board on test which showed no problem. This test was just the board
I had the same problem with an 800Mhz FSB processor. Kept getting a blue screen adn the computer would reboot. Enter the CMOS and go to the CPU setup section. Change the speed to Manual and set it for 300. The 061226 bios only supports up to a 400 Mhz FSB by default. I have a case open with ECS for a fix.
Posted on Oct 17, 2008
    President:
  • 2,351 Answers
Hi 2gerr, when you tested the board, was the board outside of the you're case?
Here is one suggestion you can try. Start the PC & press the F5 key every two seconds untill Windows Advanced Options Menu
is displayed on you're screen. You can not use you're mouse here. Use the up & down arrow keys & slide to, Disable automatic restart on system failure. Than press enter. What this should do for you is stop windows from restarting & give you time to catch what is causing windows to restart. If you receive a blue screen with an error message write it down. Press the pause key on the keyboard so you'll have time to write down the error message. It would not hurt to enter you're bios and turn off hault on all errors listed in the main menu of the bios.
Another could be the back side of the board could be touching the case. You can add a piece of a paper bag under the board.
Stopping a possible short. Lastly, enter you're bios & go the hardware monitor. Open hardware monitor & leave it there. Shut off you're monitor & walk away for about 10 minutes or so coming back from time to time & check the temp of you're CPU & mother board temp. Staying in the bios, let me know if the PC restarts.
Mike
Posted on Apr 29, 2008
Avanquest checksoft 1935 occured during installation of assembly component
Unlimiting the registry size could work:
Here are the steps:
1) Type REGEDIT in run
2) Navigate accurately to:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
3) On the right pane, locate the following
Key: RegistrySizeLimit [Type: REG_DWORD]
4) Double-click on it.
5) On the dialog box, select DECIMAL
6) Erase the previous and enter the following number:
4294967295
7) Click okay and restart computer
8) Everything will be okay, ENJOY! try to install the package again.
Jan 14, 2014 | Avanquest Checksoft 2007 Home & Business ...
Delete freeze
Depress the power button for a few seconds till the computer turns off. Wait a few seconds and restart.
Where does it freeze, during startup, or once within Windows? If you make it somewhere into the Windows operating system, restart, and during startup, peck on F8 key till you get to the B/W Startup options. Cursor down to "Safe Mode with Networking", and press the Enter key. If it makes it to Safe Mode, use "System Restore" (SR) to back up to a date before the problem occurred. If SR isn't available, or doesn't work, enter Safe Mode again, use your IE, Firefox, Google Chrome, or Opera browser to go to www.download.com. In the right-hand column of Most Popular Downloads, you'll find Malwarebytes. Download and run that program to see if the problem came from a malware infection. Follow the instructions to scan, and afterwards to remove the infections, then restart the computer.
Oct 31, 2013 | Computers & Internet
When trying to log on to my account I get the message
if its an error message
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
if you cant login to your account on your computer
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse
allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing or it might be a hardware problem
then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
hope it helps
Aug 07, 2012 | HP Computers & Internet
Hi dennis I encounted Oxcoooooe9 on my aspire 5738 how to resolve pls advise with thanks
How do I restore my computer using the eRecovery Management program outside of Windows? How do I restore my computer using the eRecovery Management program outside of Windows?
Select models, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
Note: For video guided assistance using the eRecovery Management program to restore your computer please visit our How do I restore my computer using the eRecovery Management program? answer.
To start the system recovery:
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
    Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Jun 25, 2012 | Acer Computers & Internet
Refuses to reboot
do you gat anything on your screen?
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
if the problem is still there
'restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option
Sep 17, 2011 | Computers & Internet
No sound coming form my computer
First check that weather sound driver is already installed or not.hints :>Right Click to My Computer>>Properties>>Hardware>>Device Manager>>Sound, Video and Games controller.If there is no driver you will notice a ? symbol with yellow color. During this time Just re-install the sound driver it is in your System Mother Board Driver,if you have mention you configuration I can give you the particular link.Still not working, remove the front panel audio jack from the mother board and repeat the first step.Again if the problem still persist, there might be a hardware problem better to buy new Sound Card from the market.Good luck
Aug 19, 2011 | Computers & Internet
WHEN I TRY TO SCAN FROM HP M1120 MFP THEN AN ERROR OCCURS THAT THERE IS NO TWAIN COMPLIANT DEVICE INSTALLED.
you will need to unistall the previous scanner drive on your system, after you finish uninstalling restart the system, and reinstall the driver again. during this processes make sure the scanner is not plugged to the computer system.
Feb 16, 2011 | Computers & Internet
How do I stop 'you must reboot your computer' notice that keeps appearing on every boot up. I have installed latest Adobe Reader and problem continues
If this problem occurred during the installation of Adobe Reader, then an installation error occured during the installation.
You need to uninstall it, then reinstall it again, and reboot.
Thank you,
Kenneth
Apr 02, 2010 | Microsoft Windows Vista Ultimate Edition
Restart at shutdown
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
I can give you anotther solution too
Thanks
Xeeshan
Nov 22, 2009 | Microsoft Windows XP Professional
Pc restarts automatically and unexpectedly
Good Evening Sunnyseber :
Hope that you are wellJ
You did not indicate the type of Operating System.
This document pertains to HP and Compaq computers with Windows Vista. If Windows Vista suddenly starts without warning, or restarts when you try to shut it down, it may be because your operating system is set to automatically restart when certain system errors occur. This feature of the Windows Vista operating system can be disabled. Use the information below to disable the Automatically Restart option. NOTE: In addition to the steps in this article, updating video card drivers is known to resolve many of the problems that can cause the computer to restart. Step 1: Disabling Automatically restart option to view error messages You can prevent the computer from restarting by turning off the Automatically Restart option:
  1. Click Start c00971562.gif .
  2. Right-click Computer , and click Properties
  3. Click Advanced system settings .
  4. Click the Advanced tab and select Settings in the Startup and Recovery section.
  5. Remove the check mark next to Automatically restart under System Failure .
  6. Click OK to close the Startup and Recovery window and click OK , again, and then close the System Properties window.
  7. Restart the computer. NOTE: The computer will no longer restart automatically when a problem occurs. Instead a blue screen appears with more useful information. You can now search for a resolution using the text from the error.
If I can be of further assistance, please let me know.
And, remember, always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful evening.
Sep 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
85 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
