Have a document in que - says it's deleting, but is doing nothing and the printer won't print anything...!!!
    President:
  • 2,571 Answers
There are a few ways to fix this , microsoft has a patch available.
You can also edit the registry.
Not sure off the top of my head exactly where, if you Google the problem and have a look a little futher down the page, try this
http://www.online-tech-tips.com/computer-tips/how-to-forcefully-clear-all-jobs-from-a-print-queue/
Posted on Aug 03, 2010
How can I clear the print que? I tried to cancel printing a document, and now the que says cancelling, but won't let anything else print
1) Try to restart you system with the printer unplugged.
2) Try to Pause the printer and then delete the items in the que
3) If this doesn't help Delete the printer and re-install it.
Aug 29, 2014 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet 5610v: Sent document to print. Somehow the settings were set to print offline, so nothing came out. I "unchecked" the "print offline" option. I tried to...
This Utility program resolve all the printing issue for HP Printers ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
This Utility program will fix all these issues.
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Feb 21, 2011 | HP Officejet 5610v All-In-One InkJet...
I have an HP printer. There is a full page photo that will not print. When I try to cancel the job is states deleting but does not delete. It deletes other added print jobs but not that one which is...
You have to clear out all documents one by one in the print que before you can delete the one causing the trouble. On the bottom right side of your pc screen, find the picture of the printer and right click with your mouse on it. Open your print que and right click on each document and choose "delete" until therer are none left in the print que. If this does not clear that last document, then unplug your usb cord that connects the printer to your pc and wait a few moments, and then plug it back in. This should clear it out.
Sep 08, 2010 | HP Officejet J4680 InkJet Printer
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
Today i was trying to print a document, but then when it came out of my printer, its not how i wanted it to be printed. So i pressed cancel on the printer itself. When i tried printing the document again,...
You must clear the que.
You should be able to download the print driver. Id try clearing the que first. do the three finger wave if necessary to find the process - terminate it - then reopen the que - see if the document is gone.
Unplug your printer - ower and signal ... go get a soda . when you get back plug the stuff back in ... remember - shut the stuff off first!
I hope this helps
a
Sep 23, 2009 | Office Equipment & Supplies
I attempted to print a 25 page document, with reverse pages. Only 9 pages printed. I cannot print anything now. and the message on the printer reads, DATA REMAINING. I have pushed every button...
It seems the printer buffer memory has overflowed. Cancel the print from the print Que and switch off the printer. Give your PC a reboot too. Now switch on the printer and make sure that there is no document in the print Que. If its still there, disconnect the printer and delete the pending job, i.e. print Que. After the printer shows it ready for printing do not release the entire document for printing at one go. Breakup the print job in 3 parts and for each part manually enter the page numbers and then give the print command. Repeat this till the entire lot is over..........................sodeep
Apr 14, 2009 | Brother Office Equipment & Supplies
Can not delete document in print q - nothing else will print
Open task manager,(Ctrl +Alt +delete) and end task on print spooler,delete the file.print spooler will restart automatically.
This works best if you have the que window open first.
Please rate this fixya
Jan 25, 2009 | Lexmark X3550 All-In-One Printer
Documents won't delete out of que Epson CX8400
Are you using Windows XP? If you are go to Start, Control Panel, Administrative Tools, Services and stop the Print Spooler Service. This should clear the pending print jobs.
Then re-start the service.
Jun 17, 2008 | Epson CX8400 All-In-One InkJet Printer
66 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
