Question about Dell AS501 SoundBar 2 Speakers
How do i unhook the speakers from the screen - Dell AS501 SoundBar 2 Speakers
    Problem Solver:
  • 8 Answers
You can purchase what is known as a 'keyboard hoover' from sites such as 'www.iwoot.com', for about 5 or 6 pounds. This is useful for hoovering up crumbs and things from the keyboard, and also should clear the dirt/crumbs/fluff from the speakers.
Hope this helps.
Posted on Aug 06, 2010
  • Firey5 Jul 13, 2011
    what does this have to do with unhooking the speakers?
My receiver is JVC model no KD-R526.its saying check wiring on screen
This means the amp is sensing a short, if you can it would be easiest to unhook the speakers one at time to see if it goes away.
May 20, 2016 | JVC Car Audio & Video
My Lg home thearter displays protection and refuses to produce sound
Unhook all the connections to it one at a time and test it after each item is removed. So unhook LF Speaker and try it , then the RF speaker, see if you can locate the one that is causing this. If you get everything unhooked and it still says protection, there is a part failure inside the amp.
Mar 10, 2015 | LG Audio Players & Recorders
The fade button isnt turning on the speakers in the bakc of the wagon. we just bought the car but have no owners manual. front speakers are good
They could be unhooked. If they were hooked up but blown, you would here static. If you hear nothing theyre either unhooked or the radio console is messed up.
May 09, 2011 | Car Audio & Video
When switching on the ampli, I get a message "amp
you may have a shorted speaker wire. unhook all the speakers and test each speaker by using a 9 volt battery across the speaker wires, you should hear a pop (this will not hurt your speakers). in each speaker. if you don't hear the pop then you may have found the one that is shorted. Another thing you can try is to unhook all the speakers and trun on the system (briefly) and see if the message is gone, this being further indication that you have a shorted speaker wire.
Mar 20, 2011 | Harman Kardon AVR 130 Receiver
How do i get the front screen off of a 46 inch zenith rear projection tv. it's 13 or 14 yrs old
First, unplug the unit.
Then remove the speaker grills. At the bottom of the screen there should be approximately 8 -10 +/- screws. Remove these screws and the screen should lift right off. Before unhooking the screen at the top, be sure to check that no sensors are attached to screen assembly and have a friend hold the screen while you unhook the two connector plugs that go into the back of the screen.
Jan 17, 2010 | JVC HD-61Z786 61" Rear Projection HDTV
I have an RCA surround sound system for my Big screen. Lately we have horrible static in the main speaker, is the speaker bad? If I unhook it, the rest of the speakers are fine.
Could be bad, swap it with another channel. if the problem is still in the same speaker the speaker is bad. if it still crackels in the other speaker the problem is in the amp.
Dec 30, 2009 | RCA RT2250 System
Says protect on screen
either too many speakers hooked up (bad ohm load) or internal flaw try unhooking speakers and cranking it up while playing if it stays on its the speaker wiring or even the speakers by themselves
May 19, 2009 | Sharp Audio Players & Recorders
Cant get speakers on my monitor to work after I unhooked external
IF you have xp go to control panel/sound,speech and audio. You will see a drop down choice that says change speaker settings. Click on this. Then under the tab that says speaker settings hit advanced. Then select the sound scheme that says monitor with stereo speakers and apply this. Assuming you still have a functioning sound driver this should return it to the monitor speakers. Hope this helps.
Mar 29, 2009 | HP (400745-001) Sound Card
Screen removal
pop off the front cove were the speakers are grab each side just under the screen were it is seperated. and it will pull right off. then their are two screws holding it in place on the bottom corners. after screws are removed the screen slides up to unhook.
Nov 06, 2007 | RCA P52937 52" Rear Projection Television
Dell AS501 SoundBar 2 Speakers Logo
122 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
