Question about Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Roller-Disassembly
Thank you so much for your kindness. If I attempt this would I try and unthread it? If so, clockwise or CCW? Also, any recomendations on what to use to pry the end off? I'm afraid I'll break the plastic ends if use force on them.
I do thnk this is a replacement that I got from eBay. I've had to replace too many of these damn things because of the same reasons. I've never had roller get to the stage where it wore out.
    President:
  • 1,673 Answers
I always get confused, but I think it is clock wise. Stick a small blade screw driver under the end cap and pry out, it should pop off, it covers a bearing. That is the problem with the Oreck brush rolls, the ends go bad long before the bristles get worn down.
Posted on Apr 26, 2008
The roller brush on my Oreck XL Classic has only center bristles. Both sides have been worn down to nothing. It is hard to push.Why are the bristles wearing down?
Sounds as if the wheels are collapsed on one side and the brush is harder in contact on one side. In correct alignment the brush should just kiss the top of the carpet causing the bristles to flex a little.
Oreck will fix it for you under warranty;
http://www.oreck.com/oreck-xl-classic-limited-edition-bagged-vacuum/UK2200.html
The XL® Classic Limited Edition is confidently by Oreck®'s warranty and 9-point free service tune-up inspection plan to ensure optimal performance for years to come.
Returns information is here
Returns
Oct 30, 2016 | Oreck Vacuums
Hi do you carry the roller brush parts for this model?
Hi Rochelle,
This is Leland with Crucial Vacuum,
We carry the roller brush, and some other products for the Oreck XL, which you may find in the link below:
http://www.crucialvacuum.com/catalogsearch/result/?q=oreck+xl
You can purchase replacement parts for your Oreck unit direct from Crucial Vacuum with freeshipping and an exclusive 10%coupon for Fixya.com readers, use code: FIXYA10
I hope this was helpful! If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendlycustomercare representatives on the line ready to assist you.
Jan 29, 2016 | Oreck XL Power Team Upright Vacuum -...
Suction problem
Probably have a clog some where in the base and that is what causes it to throw stuff back out.
Apr 04, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Just replaced the roller on my oreck XL, and it is smelling like burnt rubber
If the roller bearings are starting to seize the the belt may be slipping
Oct 25, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Replacement belt Oreck UPR014T XL
Ok its sounds like you need a new brush roller and change your belt
Aug 13, 2012 | Oreck UPR014T XL Pro 14 Upright Vaccum...
Roller on upright vacuum is not spinning so vacuum is not picking up dirt
Any time that a vacuum's roller brush stops spinning, this means that your belt has either stretched so much that it's fallen off of the motor, or that your belt has broken.
Here's a very helpful video on how you can replace the belt on your Oreck. This will give you step by step instructions on the belt change.
If you need to purchase a new belt, here's a direct link to a 3 pk. of belts that are used on your Oreck XL upright on our website:
http://www.govacuum.com/oreck117.html
I hope that this video repair was helpful to you! Please be sure to rate my repair helpful by clicking the thumbs up icons in the top of this repair page.
Thank you,
Chris J.
GoVacuum
Apr 05, 2010 | Oreck XL2200 Bagged Upright Vacuum
The roller on my Oreck XL won't roll when it's on carpet.
That means that the belt is stretched. You need to replace it. Here are the belts you need:
Oreck XL Belts
Mar 09, 2010 | Vacuums
My Oreck has become very hard to push across carpet
IF IT PUSHED EASILY ON THE SAME CARPET BEFORE, THEN THE BRUSHROLL IS NO LONGER CONTACTING THE CARPET IT USED TO. A NEW BRUSHROLL AND/ OR BELT SHOULD GET YOU MOVING AGAIN. TRY THE BELT FIRST, MUCH CHEAPER.
IF YOU HAVE RECENTLY CHANGED THE BELT BY REMOVING THE BASEPLATE (NOT THE RECOMMENDED WAY) CHECK BASEPLATE TO MAKE SURE IT IS FLUSH WITH HOUSING.
Jun 28, 2009 | Oreck XL Deluxe U3700 Bagged Upright...
While vacuuming it's unusually hard to push.
I see your post is from May. I just joined Fixya this month so, id you're still looking for a solution, I would saythe belt broken or is so stretched the roller isn't spinning. Here is an link to an online guide with illustrations for changing belt. Also check the roller brushes for wear and change if necessary. Hope this helps.
http://www.info-vacuum-cleaner.com/oreck-vac-belt.php
May 02, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
322 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
