Question about PK Nextgrid BlackoutBuster B6U2 UPS System
How to replace the battery in my Black Out Buster B6U
I have no manual for this unit and the back up battery is not working. How do your replace it?
  • ereeves220 Aug 30, 2008
    how do I order a new battery,and install instructions
Not hard to replace battery. It is a SLA (sealed lead acid) 12 volt 7AmpHour. Runs $20 to $30. To remove just unscrew 4 screws on the back and 4 screws on the side. The front panel snaps out from the bottom use a flat blade to push up the tab from the opening on the face plate. The unit will operate without the battery just no backup.
Posted on Aug 21, 2009
I had the same problem until I found this website with the information on how to replaced the battery on the Blackout Buster. This is a step by step on replacing the battery so far it worked out for me. Here goes the website: http://www.passwordmethod.com/content/view/134/43/ Let me know if it works out for you.
Thank You
Posted on Jan 06, 2009
This is for the Blackout Buster by PK or PowerKinetics B6U model (as shown on the bottom of the unit). I have no manual, but I have always gotten the correct battery from:
http://www.battery-consulting.com/UPS_Batteries/PK_Electronics_UPS_Replacement_Batteries/Blackout-buster-B6U.htm
You might want to visually look at your battery terminals to be sure and select the correct terminal config. Or, at least give them the s/n and model number on the bottom. IME, this is the BEST UPS I have ever had. My Father and I have each had one for almost 10 years. Now, if someone could point me to a place that sells the communication cable for it, I'd appreciate it.
Posted on Jul 27, 2008
  • newsgroupii Jul 27, 2008
    http://www.battery-consulting.com/UPS_Ba...
    (to fix incomplete link in post)
    OH HECK!!! It won't allow the full URL on one line:
    Or, just start at: http://www.battery-consulting.com/
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 28 Answers
Best to get the exact size replacement battery, but if it's not available and provided you have experience with electrical wiring and can make good connections, you could use any spare 12V battery of sufficient capacity and wire it externally to the wires that the battery normally connects to.
The wire used should be thick enough to carry high current, 10AWG. Use a 30A fuse at the battery to protect against accidental shorting.
If the battery is larger capacity than the original, it'll allow for a longer run time than the original.
Also, if you find the unit doesn't turn on or off when you push the button, check the plastic lever under the front cover that translates the up/down motion to the sideways push needed for the on/off switch.
The front plate is easily removed with a flat blade screwdriver as mentioned above, push straight up from the bottom to release the latching tab, and the front cover pops off. Unhook it from the top to remove the front plate.
You might find the lever fractured, so pushing the button doesn't do anything. I epoxied mine back as a fix. Probably would be good not to push too hard on the button to avoid this from happening in the first place.
Posted on Apr 02, 2010
  • 58 Answers
    Guru:
  • 1,342 Answers
Seems they decided not to make it replaceable. Click on Support, FAQ's
Posted on Apr 25, 2008
Won't charge fully
Carol, Black and Decker USA Factory-Reconditioned CWV9610R Dust Buster 9.6V Cordless Wet and Dry, does sound like you got a bad battery in the unit, replace battery or return if warrantied.
https://ca.answers.yahoo.com/question/index?qid=20070525003616AAhjgrS
Black Decker CWV9610 DustBuster 9 6V Cordless Wet and Dry Hand Vacuum
96V Wet Dry Cordless Hand Vac
DUSTBUSTER 9 6V HAND VAC
Mar 08, 2016 | Black and Decker USA Factory-Reconditioned...
Manual for dust buster CHV 1210
Go into the manufacturer site and put the model number in. Or go to any of the aution sites..I prefer eBay put the model in the search window...they will give you everything they have in them,,good luck
Sep 08, 2014 | Black and Decker USA Black & Decker Dust...
B&D Dustbuster model CHV1400 TYPE 1 not working (no recharge). Does it pay to replace battery or not? If yes, how do I open it up, and how do I replace battery? Price? Where do I buy it?
Sorry to say but the battery pack is 3/4 the price of a newer dust buster. The other solution is the have some one rebuild it. But I would buy a new one. Don't waste you time.
May 06, 2011 | Black & Decker Vacuums
The pool buster won't run at all.
I had the same problem when I started to use mine at the beginning of the pool season here. If yours is anything like mine when I opened it up I found the motor was completely rusted and the drive gears would not turn. I'm not sure if the batteries are dead as there was a lot of corrosion on the charging terminal. It is simple to open the case and then open up the motor/battery housing - just a LOT of screws!
The options seem to be buying a replacement battery and motor pack from Aquatech the makers and replacing the defective unit. I think the cost is around $130 but for that sort of money you can buy a new one on Ebay - depends if you have the Commercial Grade unit but I've seen that new on Ebay for $185ish too
If it is just the battery you might be able to buy a replacement battery alone from Aquatech but I haven't checked it yet - on thier site it shows only the whole motor and battery unit as a replacement. In theory it should be possible to get a set of batteries made up for a lot less than Aquatech probably charges - I saw one web posting where a guy had Interstate make him up the batteries for $28.
Frankly, the pool buster seems to have a lot if issues once it gets old (past the 1 year warranty) and the battery charger had a lot to do with the issues as it would overcharge. From my research it seems a common problem that water can enter the unit if the seals on the screw in starter fail. BTW the unit is now called the Pool Blaster but to all intents and purposes seems like the same model but with a different catch on the front holding the plastic cup to the body
Hope this helps
Jun 05, 2010 | Water Tech Pool Buster Max Cg
I lost the manual for the Black and Decker Scum Buster
how long do you charge the batteries for the S300 Scum Buster
Feb 10, 2010 | Black & Decker S500 ScumBuster Handheld...
Black and decker handheld vacuum phv1800 type 1 low battery power
Hi I know what you mean! My B&D dust buster used to do this too. The hi power boost means that it can only be used for a limited amount of time. Due to the age of the dust buster though its a sign that the battery is on its way out and regardless of whether or how long its been used or not used, batteries can lose power regardless.
Try to let the dust buster completely lose power and then charge it up for its initial burn in period of 14 hours. Also clean the connection metal strips or hole with a dry cotton bud incase there's any static or dust. Then see if it lasts longer. If the turbo mode or speed 2 is still short, then the battery is dying out.
I don't know where you are but in the UK its hard to get battery replacements for B&D products. You could check your local seller where you are if they have battery replacements but at the cost of current dustbusters it may make more economic sense to consider buying a new dustbuster.
Jun 19, 2009 | Vacuums
Advanced power options settings UPS for blackout buster?software
I have to answer this question with just plain old common sense. Get a new one! This is crazy. If you get a new one, you will have a better, more upto date and something you can handle with todays OS and obviously new batteries. That is too old to mess with. I fixed a powerware once and the plastic was falling apart and the PC board was held together with a rubber band. Not worth it.
Jun 03, 2009 | PK Nextgrid BlackoutBuster B6U2 UPS System
Shutdown software.
Go HERE
Click on "Download" on the left.
Mar 19, 2008 | PK Nextgrid BlackoutBuster B6U2 UPS System
PK Nextgrid BlackoutBuster B6U2 UPS System Logo
3,695 people viewed this question
Top PK Computers & Internet Experts
David Payne
David Payne
Are you a PK Computer and Internet Expert? Answer questions, earn points and help others
