Question about Dryers
I am working on a Westinghouse Laundromat 350 Heavy Duty dryer that only runs on one heat. The heat does not change whether the switch is in the warm or hot positions.I have a measured 7.6 amps when heating, so am not sure if this is expected on the warm or hot settings. Can you advise possible problem or provide wiring schematic
  • zahrzdad Aug 05, 2010
    Thank you for your solution. Your explanation gave me the insight into how the circuitry worked, which made it easier to find the fault. As it turned out, the thermostat was faulty. Everything is working well now. Thanks again.
    President:
  • 1,554 Answers
No available schematic diagram but there are only two possible reasons why the dryer heating cannot be adjusted. First is the cycling thermostat and the second is the heating element. The cycling thermostat has a bias heater that varies its cycling time according to the temperature setting to achieve the appropriate drying temperature. Check to make sure that the dryer temperature switch is connected to the cycling thermostat bias heater. The cycling thermostat is located on the blower housing having four terminals. The bigger terminals are the main terminals while the smaller ones are the bias heater terminals. Replace the cycling thermostat if the bias heater is properly connected to the temperature switch.
The next thing to check is the heating element. Make sure it is intact and no part of it is touching any part of the heater housing or the dryer cabinet.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 03, 2010
Whirlpool heavy duty 5cycle 3 temp dryer won't turn on suddenly stopped..no sound whatsoever..changed heating element and still not on
Check your thermal limiter . It should look like a white bar about a inch long . You can find it on the blower housing
Feb 17, 2013 | Whirlpool Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
I have model REX3514PQ0 that I purchased from Lowe's in 2005. It is a Heavy Duty, Extra Large Capacity, 3 Cycle dryer. The dryer will turn on and will blow but only cold air. A friend suggested I check...
There are three switches :: high heat thermostat, low heat thermostat, and thermal limit switch.
Could the the thermal limit switch is opened because the dryer overheated -- these cannot be reset -- need replacing.
Could also be a faulty heating element. To test these components you'll need an ohmmeter (multi-meter) and will need to remove the back of the dryer.
More info, let me know.
Charlie
Feb 20, 2011 | Roper Dryers
My Amana Heavy Duty Dryer will not heat up. It tumbles but it doesnt warm up. WE have cleaned out the the machine and the vent to the outside.
You didn't state if it is a gas or electric dryer. If gas the igniter element is bad, if electric the heating coils need replaced. Goodluck Google burdfrenzy
Nov 26, 2010 | Amana Dryers
Kenmore 80 Series Heavy Duty Electrc Dryer runs but will not heat
If it will not come on and run check and or replace the thermal cutout on the vent canister and also check and or replace the door switch.
Aug 06, 2009 | Kenmore 84052 Dryer
Trying to reinstall belt around pulleys on Westinghouse Dryer
Watch the video:
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 09, 2009 | Dryers
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
Dryers Logo
141 people viewed this question
Top Dryers Experts
Marvin
Marvin
