Question about Duracell AAA NiMH Battery Charger with 4 Rechargeable AA Battery
What should I do if my Duracell charger does not seem to be charging. I had added non NiMH batteries within 1 minute it gave a noise and when i saw non-lithium batteries, it burst with some little liquid. I immediately removed those batteries. Clean that liquid from the charger and i put it back on charging with the original NiMH cells only. I saw the red light for some time. BUt after 5 minutes that red light disappear. It seems that the charger is not working now. Please help me .. what to do now..
  • 28 Answers
You broke it. there is no fix.
The batteries you put in it that blew were resisting the charge and fighting with the unit and most likely burnt up some electronics inside the charger.
I would not use it at all or even try to use it. You may cause a fire or get zapped.
Posted on Sep 01, 2010
When I insert some batteries the red light begins blinking. I also have some Duracells that appear to be charging but when I place them in the appliance they are dead.
All chargers cannot charge all types of batteries. Are your Duracell batteries NiMH or Alkaline? These indications generally happen when you insert a battery type that is not rechargeable.
Dec 13, 2009 | Duracell AA/AAA NiMH Battery Charger with...
My 15 min. Duracell charger keeps blinking-won't work...
When the duracell lights blink during charging, AT YOUR OWN RISK, try a reverse charge. Instead charging positive to positive and negative to negative, try positive to negative and negative to positive. I did this for 2 minutes. This solved the problem. After the 2 minutes, I gave the batteries a normal charge. You will have to force the battery and charger contacts to touch.
Jul 08, 2009 | Duracell AAA NiMH Battery Charger with 4...
What color should LED be when charged on duracell NIMH charger
When the batteries are charged fully the light should be green.
Nov 27, 2008 | Duracell NiMH AA/AAA Battery Charger with...
LED Light on or off indicator
on my charger the red lights are only to tell there is power connecting especially when you have two battery's behind each other on the bottom of my charger there is a guide as to how long you should charge each battery as to size which are aaa 7hours max
aa 24hours
c 24hours
d 24hours
9v 24hours
hope this helps glenn............
Nov 20, 2008 | Duracell AAA NiMH Battery Charger with 4...
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
15 MINUTE AA CHARGER
Call duracell and explain your problem they will likely send you new batteries. They will tell you that yours are old.
Duracell if the the USA (800) 551-2355
Aug 30, 2008 | Duracell AAA NiMH Battery Charger with 4...
Flashing lights
I had the same problem. 1 of four way's can fix it. #1 Put a batt. that has a little charge in that flashing spot 1st. and see if that works. #2 put the batt. in that flashing slot first and then in the 1st slot, If that did'nt work, #3 Put Batt. in backwards for 1 sec. in and out fast. and I do say very fast, In that flashing spot. #4 buy a new one. The one that fixed mine was #1 and it stoppppped flashing, The order I put them in was - 3-1-2-4 I put in #3 batt. first, it was the one flashing And it worked, You may have a bad batt. or it's on it's way out, but try It. worked for me!
Mar 30, 2008 | Duracell AAA NiMH Battery Charger with 4...
Duracell AAA NiMH Battery Charger with 4 Rechargeable AA Battery Logo
406 people viewed this question
Top Duracell Electronics - Others Experts
Craig Butler
Craig Butler
Joseph Mueller
Joseph Mueller
Are you a Duracell Electronics - Other Expert? Answer questions, earn points and help others
