My laptop is not switching to AC mode even when plugged into Ac Power outlet. I work on battery mode and after full battery drain, the laptop goes into hybernation...once into hybernation it starts charging the battery. I bring up the laptop again it goes into battery mode only... never into AC mode even if the laptop is plugged into the AC supply.
    President:
  • 1,768 Answers
1. You may possibly have a faulty power supply adapter. Contact the manufacturer and see if there are any call backs on the power adapter for you laptop unit
2. you may also have a damaged connector at the laptop connection. This will require repair by a technician.
Posted on Aug 03, 2010
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
My Orbit 57899 is saying no ac but the outlet to where this goes is working fine
I believe that you plug a transformer into the outlet. If this transformer is not working, no power goes to the timer. Remove the battery and if the timer display goes out (and it may take some time, possibly hours) the transformer is in need of replacement. They are available at sprinkler suppliers and maybe even a local hardware.
Gary
Jul 03, 2011 | Orbit Sprinkler System Power Source...
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
Power goes out whwn I unplug ac adapter
ther must be a short in the plug, get it checked before something goes really wrong
Jun 01, 2010 | Toshiba Satellite M35X-S311 Notebook
My battery died, I plugged in the charger and the battery light flashes and then shuts off
Your battery might be completely drained. Remove your battery and and plug your laptop directly to the power outlet using just your laptop's AC Adaptor. If should now work with the battery being bypassed.
If it won't work in this way (connecting to AC Power with the battery removed), there must be something wrong with your laptop's board.
Feb 23, 2010 | ASUS Eee 4G Notebook
Will the laptop power up with a bad battery
You dont need battery to power up if plugged into mains charger.
Do any lights com on at all??
Dec 30, 2009 | Compaq Armada M700 Notebook
Blackberry curve 8900, red light will come on for eight seconds when connected to AC power then a battery with a blue lightning bolt will show up on screen. Once AC is removed device goes blank. I've put...
The battery is drain.
DO NOT use the USB cable to charge your Blackberry.
When the PC/Laptop/Mac go to power saving/SLEEP mode it will cut off the charge to the Blackberry.
Use the official AC charger to charge the Blackberry.
Make sure the AC power is not switch off to the power pack at night.
The mini USB connector can be loosen over time.
Plug in the cable and check for connectivity.
Oct 19, 2009 | Cell Phones
Flickering screen - Acer (laptop) 1690 series
You have two problems and they are separate issues.
First your battery is nearly worn out. Rechargeable batteries have a finite number of charge and discharge cycles and as the battery ages the charge capacity will drop. When the battery is worn out, it may not charge at all or show it is 100% charged but when you remove the AC power the laptop will shut off because the battery is dead. A new battery is required to fix this problem.
Second when you connect the AC adapter into the laptop's power socket, and the screen flickers and the charge LED also flicks, it means the power socket is faulty or the power socket has a dry solder joint connection to the motherboard. If you hold the power plug in a particular position you should notice the charge LED will stay on without flickering as well as the LCD screen.
This fault can be repaired, but it requires the laptop to be dismantled completely to access the power socket. I suggest you get a quote first.
Sep 06, 2009 | Acer Aspire One A150-1006 Notebook
My Compaq Pres V2000 laptop does not get on with power on switch
Take out the battery and only hook up the AC Adapter to see if the laptop turns on. If it does then you know the battery is shorting out the laptop and either has very little power to turn on the laptop or is shorting out the laptop cause its bad.
If you don't get the laptop to turn on, make sure your using a well known working wall outlet to plug the laptop to and only use the AC Adapter. If you AC Adapter is hooked up and the Green Led turns on then you know the adapter is good.
After those two steps, you can also try taking out the dvd drive and the hard drive. Then try turning on the laptop and if the laptop still doesn't turn on then the motherboard is bad in the laptop.
Aug 29, 2009 | HP Compaq Presario V2000 Notebook
I HAVE A LAPTOP ACER AND THE POWER DOES NOT TURN ON
It could be a battery problem. Try switching to AC mode by plugging in to an AC outlet using your Acer power chord (battery charger also). If the charger led don't light, it means it's defective and it can't charge your battery. Please try another power chord or battery charger then. Just remember to take out your battery when using your laptop in AC mode to lengthen your battery life. Regards!
Jul 05, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
74 people viewed this question
Alun Cox
David Payne
David Payne
