Question about GE 36 in. JGP628 Gas Cooktop
Clicking does not stop even when not trying to lite stove
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 04, 2010
Is there a pilot lite I need to light for my stove ffgf3011lw
Some stoves have pilot lights, some have an electronic igniters. If you hear a click, click, click when you turn on the gas, you have igniters.
Dec 06, 2014 | Frigidaire 30" Freestanding Gas Range -...
Red light on stove surface is lite up red and code pf is on display
"PF" displayed on the control:
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Apr 04, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
My GE Monogram Gas Cooktop model ZGU650N4DH5SS ignitor keeps sparking even after the stove is lite. What do I need to change or fix please?
Hi Ishiggs,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 11, 2011 | Cooktops
Gas stove tops: After 3-4 minutes of the gas being on for one or more burners, all of the ignitors keep on attempting to spark. They keep going even after the gas has been turned off and stop after 5 or...
Hi abbilou_78,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 30, 2011 | Whirlpool Cooktops
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
My stove top now keeps clicking, even when it is
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Mar 26, 2010 | Jenn-Air JGD8130 Gas Cooktop
The spark element continues to click at all times, even after the flame is lit. The only way we can stop it is to unplug the stove.
Each valve has a switch on it, so that when any valve is set to the lite position, all igniters should spark.
The most common reason to see your symptoms is that a person has cleaned the cooktop and water, or whatever cleaner was used, has gotten into one or more of these switches (which are located on the shaft of each burner control knob) and is shorting one or more switches. Most times, if you let it go a day or two, it will dry out on it's own and start to work correctly again. If not, you may have to replace one or more of these switches.
Jul 26, 2009 | GE Profile JGP636 Gas Cooktop
Clicking sound from GE gas stove igniters
u most likely have a gas supply valve problem, the clicking will continue until that is fixed.
Jul 22, 2009 | GE Profile JGP636 Gas Cooktop
Spark igniter discharging when turned off
Hi
It sounds like somebody clean up the stove and the electric sending unid is wet, try this: the knob that correspond to the ingniter that it's clicking nonestop, take the knob out and you will see the sending unit, pull it out unplug it and dry it out and then try it again, it should work properly after it's dry.
Eddie Rentas
Tupper Lake NY
Jan 11, 2009 | GE 30 in. JGP328 Gas Cooktop
GE 36 in. JGP628 Gas Cooktop Logo
69 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
