The engine normaly work but i have low pressor
    Guru:
  • 551 Answers
There are two ways:
1. Replace the processor with the same specification of your processor. This time it should be in higher speed. Like 2.0Ghz or more. But be sure it will fit your motherboard. Because if not, it will not work. 2. You could replace your motherboard, processor, memory and reinstall your operating system.
You choose what is more cheeper. If you will ask me, upgrade everything. So that in the future you will not having problems on speed and processing.
Posted on Aug 03, 2010
Bar that sewng foot is attached to for raising & lowering suddenly will not drop sweing foot all the way down to plate. Any suggestions on how to fix?
Perhaps you accidently moved the switch that enables free hand embroidery? It's up and under next to the pressor foot lever. Slides forward and backward. Forward the pressor foot will go all the way down to the feed dogs. Slid back and it keeps the foot up off the feed dogs but allows the thread tension to work properly. It would be easy to accidently move it when operating the pressor foot raise/lower lever.
Aug 31, 2014 | PfaFF Sewing Machines
I have a 96 dodge truck that dies when I put it into drive
bad fuel or low fuel pressor or dirty fuel filter
Aug 29, 2013 | Cars & Trucks
Lifter noice &and it oil lose oil pressor after 30 miles
Sounds like your oil pump is defective. If you haven't taken it to a mechanic, I'll suggest that you do so immediately to prevent further damage to your engine. Good luck and let me know how things play out.
Apr 17, 2012 | Dodge Durango Cars & Trucks
Where to find a not snap-on 1/4" with edge pressor
Go to www.allbrands.com and you can buy a low shank screw on presser foot. I am assuming that it is a low shank. (I looked up your manual on www.singerco.com for free) It is $14.95, I think. Good luck
Nov 20, 2010 | Singer 4830
A/C Green Light Flashes & only get warm air tru vents
dear sir
please check quantity of gas (freon) may there is low gas problem check gas pressore and make sure it should be parrallel of car needs if gad pressore is sufficient then problem in compressor may be it has been low efficiency so please .it should be change .
hope the answer the question
thank you.
Jun 27, 2010 | 2003 Toyota Camry
Gdi engine issues
I got the same trouble, launch shows Air Flow Sensor, Fuel Pressur switch. Ireplace both few hours OK but again same trouble.
GDI got a common truble its high pressor fuel pump.
check fuel pressor if its low thats the prob
bye
Mar 23, 2010 | Mitsubishi Outlander Cars & Trucks
Air conditioning does not work. Fan in front does
THE MEANS YOU AC IS EMTY CHECK ONE OF AC. LINES LOW PRESSOR TAKE THE TOP OF AND STICK SAME THINK INSIDE THE HOLE TO SEE IF THERE IS SOME PRESSURE COMES OUT
Jul 18, 2009 | 2004 Honda Odyssey
Leaks after it builds up pressor
hello, have you checked your pressor relief valve to make sure it has'nt gone bad it's located on the bottom of your tank.
Mar 27, 2009 | Air Tools & Compressors
Discharg pressor
discharge in technical term is the output of the compressor. the discharge pressure. where as the pressor you are referring to could be the compressor. the motor of the unit.
i hope i was able to help you,
tnx 4 using fixya,
drcool
Oct 02, 2008 | Quasar HQ2101SH Air Conditioner
Computers & Internet Logo
14 people viewed this question
Alun Cox
David Payne
David Payne
