Why i unable to use the printer panasonic kx-p1121( paraller cable to usb cable ). after installed the printer only print out some funny code.pls advise
jackboy
  • 2985 Answers
SOURCE: how to get panasonic printer driver kx-p1121
http://www.printcountry.com/drivers/PANASONIC_KX_P1121_DRIVER_DOWNLOAD.htm
Posted on Jun 09, 2008
AvioriX
  • 689 Answers
SOURCE: panasonic kx-p1121 driver
Dot matrix printers usually work with IBM compatible native drivers. I have tried similar model with Vista worked fine. You may need to perform manual installation by using LPT1 parallel port. If you cant see similar model in the list you can choose generic text printer or IBM Proprinter.
Good Luck
Posted on Nov 10, 2008
Benimur
  • 6966 Answers
SOURCE: panasonic KX P1121 how to choose USB printer port for my laptop
Hi and welcome to FixYa,
Initially, a couple of ideas you may want to try:
  • goto Start (or Control Panel), Printers (& Faxes);
  • if the Panasonic KX P1121 has been installed, right click on its icon;
  • click on Properties;
  • click on Ports tab;
  • scroll down till USB... Virtual printer port fo.....;
  • click to check/enable;
  • click OK button;
  • ensure no Pending print jobs/Cancel Print;
  • try printing a test page;
  • in some instances, a reboot may be necessary;
  • in most instances when installing, the printer through the USB connection should not be connected yet;
  • connect printer to computer through USB only when instructed by the installation program;
  • if errors persist, uninstall, re-do clean fresh installations.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 19, 2008
  • 208 Answers
SOURCE: USB to Parallel connection (Panasonic KX-P1121)
I assume you installed the driver that came with the cable. The driver should create a new printer port like lpt1. That's the port you should use in the printer configuration.
Posted on Sep 02, 2009
  • 338 Answers
SOURCE: panasonic kx-p1121 using usb port.
hi solution may be simple:
back in the times of DOS USB was not up to date, so older applications(if run in DOS mode) may not b ebale to address the usb port.
Posted on Sep 08, 2009
KX-FLB756 Grinding Noise, Unable To Print
if you have driver for this printer pls. install
thanks
alamri
Dec 24, 2011 | Panasonic KX-FLB756 Plain Paper Laser Fax
Can't find printer driver for panasonic kx-p1121 windows xp
HI.................... NEED Panasonic KX KX-P1121 Printer Drivers???
panasonic_091012_021220_128.png NOTICE: Panasonic's current KX KX-P1121 driver release resolves driver conflicts, improves your computer's stability and restores communication with all KX Printers. The newly released KX KX-P1121 drivers are a high priority update recommended for all Panasonic users.
Description Version Estimated Download Time KX KX-P1121 Driver
(Includes, WHQL certified drivers)
Current as of
(Sep 26 2011) 56K: ~9m
512K: < 1m download.pngDownload
Installation Instructions:
  1. Click above Download link or Click here to begin installer download.
  2. Click "Run" ("Save As") if using Firefox
  3. Click "Run" Again
  4. Follow on-screen prompts to complete installation.
Important: If you are using Firefox or Netscape as your browser, you will be directed to save the application "to disk" (we recommend that you save the application to your desktop).
We recommend that you save it to your desktop and initiate the free scan using the desktop icon. Should you choose not to save the application, you may simply initiate the free scan by clicking the "Run" button on the File Download Window.
You can also search for a specific driver below:
Locating updated drivers is easy! driver_manufacturer_123.png driver_select_4.png Download Drivers New Version Of Windows? No Problem!
Upgrade smoothly by finding the correct drivers for your KX KX-P1121 printer for Windows XP, Windows Vista or Windows 7. For the first time, users can upgrade with confidence knowing that their computer will run smoothly thanks to the latest drivers and updates required for a perfect upgrade.
Why Updating Drivers Is Important
Usually the only reason we look to install or update drivers is because something is malfunctioning. This is not the only reason you should keep your drivers up to date however. Panasonic is constantly tuning and improving performance of their KX KX-P1121 printers and the only way to make use of this is by having the latest drivers. Going online and checking for new drivers all the time can be frustrating and is not an effective use of your time, and a simple tool like the driver installer above can keep all of your hardware running on the optimal drivers with top performance.
Sometimes when new hardware is installed, although it works correctly, other hardware which interacts with it may not be, because the other hardware actually needs its own drivers updated. This kind of co-dependency is another common problem and a reason why it's a great idea to have a tool that is constantly monitoring the state of all of your drivers and updating appropriately so you can upgrade and add or remove components in your computer while continuing to run without a hitch.
When your KX printer is relatively new, it may be possible to download individual drivers directly from Panasonic without incurring additional charges. If you are having problems locating the correct drivers for your Printer printer, or are unsure of the exact model, we suggest you run a system KX scan first. It's very important you know the exact model of your Panasonic KX KX-P1121 printer you would like to update to ensure that it will function properly and to prevent possible damage to your system. Click here to download an installer that will automatically scan and identify your Panasonic to make sure you are installing the correct update and will also locate and download any additional driver and bios updates your pc may need.
recommended.png Install the latest KX driver updates now.
  • Automatically Updates Panasonic KX Printer drivers and all orther missing or out of date drivers using advanced scan technology.
  • Instant access to unlimited device drivers.
  • Starightfoward and intuitive interface
  • Better PC performance and improved stability
  • Access to the largest drivers database in the industry
  • Continous updates for the latest manufacturer drivers
  • Unlimited free technical supports with our 24x7 technicians
HERE IS THE LINK OF DOWNLOADED FILE.....................
http://xpdrivers.com/printer/panasonic/kx/kx-p1121/_5_5908.cfm
GOOD LUCK..................
Sep 26, 2011 | Office Equipment & Supplies
Download parallel printer cable to usb for panasonic KXP1121 driver
Go manually, install it by [Add Printer] in the control panel, follow the wizard. Remember not to tick the option for [Automatically detect and install my Plug and Play printer], then choose 'Panasonic' in the Manufacturer column and 'Panasonic KX-P1121' at the printers column.
Jan 15, 2011 | Computers & Internet
I gone a cd download,so i want panasonic kx-p1121 printer sofware..how can i download..
Panasonic KX-P1121 Drivers are included in Windows XP. Go to Contral Pannel, Add Printer and Install.
CreativeTECH
Dec 24, 2010 | Panasonic Office Equipment & Supplies
TO DOWNLOAD PANASONIC KX-P1121
Try to find at yahoo or msm websearch to get free printer installer software for your printer. Just type the model print and you can download it for free.
Nov 11, 2010 | Office Equipment & Supplies
Panasonic kx-p1121 using usb port.
Sep 08, 2009 | Nikon COOLPRINT Thermal Printer
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
I want driver for Panasonic KX-P1121 for XP
help,,,,please solve the panasonic kx-p1121,cannot print,still status off line ? why cannot use?? somebody can help...TQ Verry much....
Feb 25, 2009 | Panasonic Office Equipment & Supplies
Panasonic KX P1121 how to choose USB printer port for my laptop
  • click OK button;
Dec 19, 2008 | Canon LBP 800 Laser Printer
Panasonic kx-p1121 driver
Good Luck
Nov 10, 2008 | Panasonic KX-P1131 Matrix Printer
55 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
