Question about Cameras
I have a Canon S400 digital elf. Suddenly, the lens doesn' open....after recharging battery. I get a beep followed by buzzing....and the screen says 'E18'? Can you help. Thank you Mickey Chasse
  • 477 Answers
This is a very common problem with several digital cameras the buzz sound it the motor being obstructed. and it is giving you a lens error some times you can tape the camera on its side gently while turning it on and free the jam some times not. if not you need the camera serviced. I repair these all the time because of this problem. Cost for repair are normally 65.00 plus 10.00 labor and 8.00 for shipping the camera back let me know if I can help you any further on this issue.
Posted on Apr 25, 2008
Y Canon Power Shot SD400 digital Elph camera won't shut down
Your problem in your lens...Try to bring service center. Cause, canon lens it for me it not easy to disassembe dan assemble it again...Different with other camera lens, like KODAK and Samsung.
At sony camera "E18" can be "Turn the power off and On again" like my Sony W.35
Aug 22, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Black screen, put in new battery no change!???
For both of your cameras, this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
I highly recommend that you follow up on this, especially for the SD110. I think you'll be very satisfied with Canon's excellent customer service!
Apr 26, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Can't take pictures
If the lens is buzzing and followed by an "E18" or "lens error" message then the lens will need to be replaced. If no message appears you may just have flat batteries or even a single bad battery can cause this. Try getting some good quality disposable batteries specifically for digital cameras. If all is well with the new ones, invest in a new set of rechargeables.
Mar 24, 2009 | Canon PowerShot A95 Digital Camera
Canon S400 Pictures are over-exposed with horizontal lines-LCD ok
For both of you, this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Dec 27, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Cannon A620 won't work
I cannot access my 'Date Stamp' Function. the display is dark on the screen any sugesstions.
Sep 13, 2008 | Canon PowerShot A620 Digital Camera
E18
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
It's important that you fix the E18 error first, as the blur of colors may be symproms of a failing CCD. If so, Canon would fix this for you for free IF the camera has no other problems (ie no E18 lens error). Please see the following info:
May 27, 2008 | Canon PowerShot A70 Digital Camera
Black screen, loud beeping when opened, doesn't work
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
Dec 23, 2007 | Canon PowerShot S60 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Canon ixus 55 - stuck in open position after sand intrusion
DON`T OPEN THE COVERS - YOUR SELF!!...You have to use ESD!!! Your cameras optical-unit needs operation. It`s not "self-made"-project!
May 10, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon ixus 400
throw it and a new one a bit more modern.
Aug 20, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Cameras Logo
105 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
