Question about Cameras
I have Nikkor 105mm Micro lens. It was used extensively in the desert. It seems minute sand particles have been deposited inside the focussing barrel. Manually it can be focussed. But on auto focus mode it is not working. Can I rpair it myself. I am in Saudi Arabia I don't find any repairer here. Even Nikon dealer is not helping me.
  • 10,515 Answers
If the minute sand particles is in between the focus ring and lens barrel, you need to get it repaired. If it is superficial and only in the seam of the focus ring, you could try to cleaning with paint brush and some iso-propyl alcohol or methanol.
Note - DIY is never recommended in these problems as more often i have seen people damaging the camera's more often than repairing it.
Good Luck!!
Thanks!!
Posted on Aug 03, 2010
The kit lens has stopped auto focussing all together, just makes a noise every now and then.
Two possible reasons ... A: the ribbon cable which runs from the rear mount contacts to the mid barrel has either cracked or broken (this eventually happens with continued zooming at some point in its lifetime) B: the focussing gear cog has small particle such as sand or broken plastic debris which prevents auto from fixing to focus point.
Solution is to try using a blower from rear at full extension to see if it is debris ...or inspect ribbon cable.these are readily available on eBay as replacement spares.
Jun 06, 2015 | Canon EOS 450D Digital Camera with 18-55...
How to clean the focusing lens?
First question: where is the dust?
If the dust ist outside the cam: no problem. Try a soft brush and remove bigger particles, then take a thin microfibre cloth and clean the dust film on the lens. Be careful - every sand particle scratches the coating, so use the brush!
If the dust is internal it's more complicated.
May be the dust is on the focussing screen. If you dismout the lens, there is a litte lock on the top inside the cam. Do not open without having special tool. Each fingerprint on this little plastic plane is not removable. It's an extreme sensitive fresnell lens.
Don't try to clean that with cloth or brush. Only airflow is allowed.
If this dosn't help - use the Canon service or replace the focussing screen with a new one (as Example Canon EF-D).
Dec 31, 2010 | Cannon EOS 50D Digital Camera
I set this "Nikon 105mm f/2.8G ED-IF AF-S VR Micro-Nikkor Lens" or tried to set it to F2.8 in full manual mode. the F-Stop wandered from F2.8 to F3 / F4.5 depending on where i pointed the lens. I...
You have described Aperture priority mode: you set the f/stop and the shutter speed changes to make the exposure correct.
Full manual mode requires you to set both the shutter speed and the f/stop. You are seeing the recommended f/stop for the shutter speed you have selected.
Sep 25, 2010 | Nikon 105mm f/2.8G ED-IF AF-S VR...
My nikon 105mm VR AS F2.8 makes a strange noise while focus and then after i remove my finger from the shutter it make a click noise as well ? is that a problem ?
As far as your focus is happening htere is no case to worrry. If the camera is set to auto focus then while you point if the focus is set right , you can just ignore this case. However if the focussing is not perfect it is possible that there could be some dust dirt or sand particles in the system which incidentely must be looked into by opening the camera. the click could be that the focus is falling in line and as such need not worry much. Use the manual focus to extremes and try a gentle tap to get any such foreign particles out of the system. I would advice not to open the camerra unless there is a serious focus fault. Otherwise continue to make use for the best. Good day
Aug 02, 2010 | Nikon 105mm f2.8 G ED AF-S VR Micro Lens
Lcd screen says lens contact problems, clean contacts but how?
There are different methods, but the two safest ways are to either use a q-tip (UK=cotton bud) dry at first with firm pressure to rub off any grease/deposits and then lightly moistened with pure alcohol. The other main method is to use a clean pencil eraser on the contact surfaces. It must be a clean eraser surface: a soiled one will leave conductive graphite deposits which can cause further problems. Be careful not to let the debris from the eraser enter the lens or the camera body. DO NOT use an ink eraser: they are very abrasive and this may seem like a good thing, but the abrasive usually consists of fine metallic particles (conductive) or fine sand/carbide particles which can ruin your lens/camera even oif only a minute amount gets into the unit.
Feb 12, 2010 | Canon Cameras
Clean fungus rear lens
Oh This Could be a problem. But try just wiping it with a lens cleaning kit. If that dosnt work take it to a camera shop and let them work on it.
Aug 28, 2009 | Nikon Telephoto AF Micro Nikkor 105mm...
Camera will not take picture with nikkor 105mm lens
Check if the lens is properly mounted. If still you get the error message, clean the electrical contacts between the lens and the camera using an eraser. Take care not to let any dust fall into the body. Attach the lens and try.
Feb 10, 2009 | Nikon 105mm f/2.8G ED-IF AF-S VR...
Im looking for user guide for Nikon Micro 105mm 2.8D lens. Where i can find and download it ?
http://mesnotices.fr/annexe_AF%20S%20VR%20MICRO%20105MM%20F%202.8G%20IF%20ED%20LENS%20ERRATA_NIKON_AF%20NIKKOR-_E.htm
or
Jan 30, 2009 | Nikon Telephoto AF Micro Nikkor 105mm...
Auto focussing problem with nikon d90
This is most likely a problem with the lens. Do you have the switch on the side of the lens at 'A'? Are you able to focus manually? It is a common fault that can occur if the lens has receive a knock or the camera has been dropped. Also, grit or sand in the lens mechanism could cause this. It is recommended that you send this camera to a qualified service centre.
Nov 22, 2008 | Nikon D50 Digital Camera
Cameras Logo
16 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
