Question about Samsung SCX 4521F All-In-One Laser Printer
Samsung scx451f printer while i take a xerox means it displays " function impossible " open heat error please give solution for this error
  • 360 Answers
This is about heating problem sometime your machnie heater roller thermister is damage repalce it
Posted on Aug 03, 2010
Fault code 042-325 on xerox 6280 color printer
error code 042-325 on xerox mean the problem is the main drive motor.
Jul 22, 2014 | Xerox 6280DN Laser Printer
I have more than three machine Xerox PE16, One of them give me Error "Open Heat Error" What can i do
OPEN HEAT ERROR (When warming up, it has been lower than 68 °C over 25 sec)
Meaning : Thermister is not connected to main board or contact point is loose at power on.
Solution : Check thermister contact point, Heating Lamp & Thermostat.
Aug 08, 2011 | Xerox WorkCentre PE16 All-In-One Laser...
I need manual or a scx451f please
Hello
click here to download the manual for your printer.
Well... I am new to fixya, so please don't forget to appreciate the solution.
Jan 27, 2011 | Samsung SCX 4521F All-In-One Laser Printer
My copier keeps flashing open heat error! What does this mean?
your thermostat has blown on your fuser. you need to replace the main board and the fuser. this is a pretty common problem on the samsung scx-6322dn which is practically the same machine.
Dec 15, 2010 | Xerox WorkCentre M20i All-In-One Laser...
THERE IS A DISPLAY ON XEROX PE220 THAT OPEN HEAT ERROR & THERE IS NO PRINTING
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Oct 05, 2010 | Xerox PE120i Laser Printer
Open heat error what does it mean and How do I
Turn off your printer, unplug the unit. Then plug it back in and turn it on.
This error message means that the printer needs service. See the following URL for more details: http://www.xerox.com/office/PE120kb/,case=R1018019549
I wish that I could be of more help.
Apr 14, 2010 | Xerox PE120i Laser Printer
LSU error message
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Apr 27, 2009 | Xerox WorkCentre 220 All-In-One Laser...
Samsung scx 4200 laser printer diplay says open heat error"
Good Day Sir,
Your machine display "open heat error" it means there is a problem in the fuser unit. I suggest unplug the power cord and plug it back again. If the problem persists you must call for service.
thank you.
Apr 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Xerox Phaser 8500DN printer error : 09,037.45:67244
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Mar 05, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox Workcentre M201 says open heat error
Fuser Error, Open Heat
Error, Heating Error and
Overheat
There is a problem in the
fuser unit.
Unplug the power cord and plug it back in. If the
problem still persists, please call for service.
Dec 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Samsung SCX 4521F All-In-One Laser Printer Logo
500 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
