Question about TruTech PLV1615T 15 in. LCD Television
Does this television have a QAM tuner? - TruTech PLV1615T 15 in. LCD Television
DOES THE SEIKI SE20HY 20 INCH CLASS HAVE A BUILT IN QAM CLEAR TUNER?
This LED has QAM clear tuner as per manufacturer specifications.
Jan 01, 2016 | Seiki Televison & Video
Comcast cable has stated that i need a cable box unless i have a tv with a QAM tuner. Does my Emerson LF391EM4 flat screen TV have a QAM tuner?
Depends on where you get your service. Where I liveon East Coast of US, ya got to have a Comcast box (DTA Digital Transit Adapter) or better) PERIOD. Currently, there are no TV sold in my area that can beat the Comcast system. It may be different where you live.
Aug 05, 2014 | Emerson Televison & Video
Activate QAM Tuner
QAM tuner fault. Contact any service technician to replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 28, 2014 | Westinghouse LD-3235 32in LED 720p Flat...
Does my tv have a QAM tuner
The Polaroid FLM-323B does not have a QAM (clear digital cable) tuner. It only has NTSC (analog) and ATSC (digital OTA) tuners. Retrevo has the manuals for the Polaroid FLM-323B here: http://www.retrevo.com/support/Polaroid-FLM-323B-TVs-manual/id/279ag018/t/2/ . You will need to enter a code to access the PDFs.
I wish that I had better news for you.You will need a set-top box if you want to watch digital cable.
May 21, 2012 | Polaroid FLM-323B Television
Is this TV equipped with a QAM filter to receive digital broadcast
It doesn't appear that this television has a qam tuner. I double checked by consulting the specs. They are on page 57 of your manual.
Mar 07, 2011 | Toshiba 15DLV76 Television
I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
Hi.
No, your tv is an older model sdtv with an analog only NTSC tuner.
Newer model have an ATSC/Qam digital tuner, but not your model.
This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
Once in a great while you might even find one that has s-video output, but those usually are expensive.
I hope this helps you out.
Feb 08, 2011 | Jensen TS2050J 20" TV
My Brand New 40" westing
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals:
http://en.wikipedia.org/wiki/QAM_(television)
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
Can't view local HD with built-in QAM tuner on Sharp Aquos LED
I found this solution at ehow.com and it works: http://www.ehow.com/how_5417083_hd-channels-comcast.html. You'll just have to switch over to another input to view the HD channels.
Dec 03, 2009 | Sharp Televison & Video
Does this model have a built-in QAM tuner?
Yes it does.
  • Includes built-in ATSC/QAM/NTSC tuner for off-air HDTV and SD (standard-definition) reception
  • Accepts high-definition 1080i, 720p, and 480p signals from DTV set-top receivers and progressive-scan DVD players
  • Side-panel A/V hookups and controls allow easy connection with a camcorder, gaming console, or other device
  • Aug 15, 2009 | Samsung DynaFlat TX-P2775H 27" TV
    TruTech PLV1615T 15 in. LCD Television Logo
    46 people viewed this question
    Top TruTech Televison & Video Experts
    Bill Wright
    Level 1 Expert
    Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
