Question about Dewalt DC618KA Angled Nailer Kit
Gun will not set nail all the way - Dewalt DC618KA Angled Nailer Kit
  • 700 Answers
This indicate insufficient air pressure, increase slightly air pressure till you obtain desire depth of penetration of the nail. that i smost common cause
you may have some problems with piston movement, but this will as well very sharply recoil, you did not mention re-coil, therefore insufficient air pressure is correct assessment.
if you find my answer helpful, do not hesitate to vote, thanx!
Posted on Aug 03, 2010
  • 1 more comment
  • liammadigan Aug 04, 2010
    a dewalt dc618 (my fault for not specifying), after firing the nailgun it leaves about 2" of nail sticking out and will not drive nails in any further. the bands and belt seem to be fine???
  • bzet1820 Aug 05, 2010
    Ok, after short clarification, I assume therefore that you use standard 2 1/2" nail, and it is driven only about 1/2" inot the wood.
    Most common causes in this gun, especially if was operating correctly before are:
    1. Battery, does not hold charge or is not cahrging fully, check tool against known working and good battery
    2. Nailer is not in full contact in place, need to be pushed harder against the surface
    3. Wood is too hard, this is actually more common than it is menioned, choose tool suitable for the job
    4. Nail too long for the application
    5. Broken or worn driver blade tip/shaft. You need to replace driver/return assembly, it is usually better done in repair workshop, albeit is not that difficult, for experienced person takes about 20min.
    6. Damaged or worn driver/return assembly, same as 5... need replacement.
    7. Most common cause of your problem: depth adjustment too shallow, follow general tips for that below:
    There is little wheel on this gun which regulate release pressure, it is located on the side of the tool, you need to check if it is correctly set up. On average, longer the nails, harder the timber, higher the settings.
    Follow this procedure:
    a. Remove battery
    b. Remove nails from holder
    c. Secure contact trip lock-off
    d. Rotate wheel clockwise up to 6 (that is maximum)
    e. Re-assemble battery and try test fire
    If problem persist, I am afraid that you need to check other possibilities listed, check batery first, it is cheapest.
    DeWalt is providing with this particluar model 1 year exchange warranty regardless of reason (worn assembly as well!) and 3 years service, that is depending on country of sale, please then check if yours is still under warranty, you maybe due for new gun or at least refurbished one :-)
    I know it is in punjabi, but I do not speak that particular lingo...
SETTING SHORT NAIL DEPTH
If you have tried the depth adjuster lowest setting and still too high, try lowering the pressure to the gun. The shorter nail does not give enough resistance allowing the driver to slam against the lower bumper inside of the gun (made of rubber or vinyl) forcing it to compress. There might be a rubber protector that installs on the safety foot of the gun that will space the gun away from the work another fraction of an inch. Finally, you could use a thin piece of wood under the safety foot /nose to space the gun away from the work. Good luck
Apr 05, 2013 | Tools & Hardware - Others
My Hitachi nv65ah nail gun won't set nails into 3/4 trim. I have played with the turn/screw set adjustment and it is set for the deepest setting. This gun was purchased second hand off e-bay but
If every nail is stopping at the exact same height, a likely reason is the tip of the driver is broken off so it's not long enought to drive the nails all the way to flush. If the height of the nails is slightly different you may have worn or broken o-ring(s) inside the gun and air is leaking around the driver's piston or elsewhere in the gun so that the driver isn't getting full pressure. You can take the gun apart and inspect the o-rings. If you push the driver all the way down the tip should come flush or slightly past the end of the nose piece (not the safety tip). Parts are easy to find online or at a service center if you have one nearby.
Mar 10, 2012 | Hitachi NV65AH 212Inch Coil Siding Nailer
Adjusting airpresure
There is nothing on a nailer to adjust the air pressure. You have to do it at the pressure regulator. It is feasable to mount a regulator at the gun but more likely it's on the compressor. Most nail guns are rated for 90 to 120 psi. Set your regulator to hold the hose pressure between 90 and 100 psi. Using higher pressure to set the nail will ruin your nailer. Use the depth adjustment on the gun to set how far the nail is driven.
Sep 23, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Nail Gun support
Yes, because there is less risk of splitting the wood grain when using a nail gun than when using a hammer, nail guns are especially useful in delicate projects such as the application of indoor trimming. A nail gun sets the nail in one motion, reducing the chance of slips and bumps that can ruin delicate woods. Most models also include a rubber safety nose to protect the wood from friction.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Nail Gun Problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Nail Gun cost
A good-quality starter set, including both a compressor and a small nail gun, can be bought for around 200 US dollars (USD). More sophisticated models can reach 1000 USD or more. Optional features such as a hard-shell case, safety trigger, and depth adjustment can drive the price even higher. For one-time jobs, a nail gun can also be rented at hardware stores and home repair centers.
Aug 27, 2008 | Bosch 18V Cordless Planer 53518
Delicate problem
Aug 27, 2008 | Arrow No. ET100 Electric Heavy Duty Nail...
Nail Guns costs
Aug 27, 2008 | Arrow ET200 Electric Brad Nail Gun
How to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Aug 27, 2008 | Mountain Air Blow Gun with Rubber Tip
Dewalt DC618KA Angled Nailer Kit Logo
264 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Tim Venetis
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
