1. A river flowing at 3m/s due east. A boat, whose speed in still water is 5m/s, is steered in the direction on a bearing of 330degrees. Find the resultant velocity of the speedboat. 2. The speed of an aircraft in still air is 300km/h. The wind velocity is 60km/h from the east. The aircraft is steered on the course in the direction 060degrees. Find the true velocity of the aircraft.
  • 3 Answers
1) 7.7447 m/s due 341.17 degrees
2) 274.95 km/hr due 70.893 degrees
Posted on Aug 03, 2010
I need a map chip & onwers manual for a Lowrance HDS 5 like insight. Serial no. 102574610. Where can I get them?
here is the manual
HDS-5, HDS-7, HDS-5m & HDS-7m - Lowrance
https://www.lowrance.com/.../Lowrance.../HDS-5-7-5M-7M_OM_EN_988-10041-00...Sonar references do not apply to the HDS-5m and HDS-7m GPS only units. Manual Conventions. When you are instructed to press a button in this manual, the ..
Software Upgrades here
Lowrance HDS 5 Software Google Search
and finally Mapping
mapping for Lowrance HDS 5 Google Search
and specifically, INSIGHT
Insight Genesis - Download free Lake, River and Coastal Maps
https://gofreemarine.com/insight-genesis/Make your own maps and download free maps from the community. Insight Genesis' cloud-based software does all the work, automatically processing ... with sonar signals from your existing Lowrance, Simrad or B&G transducer. ... The cloud automatically backs up all your data, protecting against lost or damaged SD cards.
Jun 26, 2017 | Lowrance Boating
Where is the Red River? In Texas
the Red River is the second-largest river basin in the southern Great Plains.[4] It rises in two branches (forks) in the Texas Panhandle and flows east, where it acts as the border between the states of Texas and Oklahoma. It forms a short border between Texas and Arkansas before entering Arkansas, turning south near Fulton, Arkansas and flowing into Louisiana, where it flows into the Atchafalaya River. The total length of the river is 1,360 miles (2,190 km), with a mean flow of over 57,000 cubic feet per second (1,600 m3/s) at the mouth.
Aug 30, 2014 | Genealogy Family History Texas Land Survey...
A swimming pool is 7m long, 5m wide, 1m deep at the shallow end, and 3m deep at the deep end.The floor slopes evenly. What is the volume (in m3) of water in the pool?
The best way to solve this is to break the total volume of the pool up into two simple shapes.
The upper volume of the pool will be a simple rectangular solid with the following dimensions:
L=7m
W=5m
D=1m
Volume of this section = L x W x D = 35 m^3
Now the lower volume of the pool will be a a triangular prism solid with he following dimensions:
Base=7m
Height=2m (3m total - 1m top section)
W=5m
Volume of this section = 0.5 x B x H x W = 35m^3
Now just add these two sections together to find the total volume of the pool:
V1 + V2 = 35 m^3 + 35 m^3 = 70 m^3
Therefore the total volume of the pool is 70 cubic meters.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 29, 2011 | Office Equipment & Supplies
How do the rivers leave the soil brought by them in the plains?
The amount of soil the river can carry is due to the speed of the water. When the water slows down some of the soil will fall out of suspension. J.
Jun 01, 2010 | Answer Carbon Expert BMX Handlebar
What role does the trim tab on an outboard play as far as handling and hard steering, and how do you adjust it?
If you are talking about the small tab under the cav. plate.Its job is to counteract the effect that the prop has on steering.Because the props. spin in one direction,they create a sideways pull on the motor due to the prop biting into the water and trying to pull all with it.2 motors on the 1 boat often have a different gearbox fitted,and one will spin in the opposite direction and this counteracts torque steer.To adjust yours,work out where you drive the boat most.Speed etc.Higher speeds have more effect.If it pulls right,adjust it left.One bit at a time.I think yours will have an allen key or hex screw above the tab.Loosen it,move the tab.Takes only minutes.I hope this helps
Sep 23, 2009 | Bass Pro Boating
Find the magnitude of the velocity of the canoe relative to the r
Firstly, though the answer is expressed as an angle "south" of west, the canoe will be traveling southeast, so the degree should be read south of east, not south of west. The ultimate velocity of the canoe will me 1.065 m/s.  The direction is 22 degrees south of east, or 158 degrees from West, but not 158 degrees south of west, since beyond 90 degrees south of west you have south. I used trig and I passed calculus so I'm pretty sure i'm right.
Dec 02, 2008 | RTO 14 Foot - Strip Built Wood "puddle...
How do iI chose a fishing boat?
There are three styles of regular fishing boats; deep v, regular v or modified v. The v determines how well the boat cuts through the depth of the water. The deep v is better suited for large lakes because they can handle heavy waves better. Regular "v" is more appropriate for smaller lakes and a man made body of water. As the water is not as deep and the waves are not as heavy, this type of boat is able to handle the situation. The modified v is the most popular version. It is capable of handling speed best. Most fishing boats on the market today are made of fiberglass or aluminum. What is best for your fishing situation? Do you want to fish in large lakes or small lakes? The options are endless. There are several classes of fishing boats for different situations. All purpose fishing boats are great for your basic fishing needs. This type of boat has space for some bench seats, fishing gear and a simple steering station. They are made of either fiberglass or aluminum and are between 15 and 20 feet long. Another type of fishing boat is a bass boat, which comes fully equipped with space for rods and fishing gear. The boat is fully built with electronics and livewells. This boat also is made out of fiberglass and aluminum. The advantage to this type of boat is it is made especially to catch bass, fast. The third type of fishing boat is the center-console. It allows a fisherman to angle from any place on the deck. The control center is located in the center. Depending on the size of the boat they can be used offshore as well as near. Flats boats are mostly made up of fiberglass. The advantage of these boats is they allow easier angling access to saltwater flat fish. Another advantage it has is a poling platform that allows for fish spotting. Finally, a casting deck allows the angler to keep control. This makes this ype of boat convenient for fishing. The final category of fishing boats is the fun boat because it combines the motor of a yacht and the functionality of large a cockpit to work trophy fish and bring them on board. If ou are a fishing fanatic then it is important to have all the things that you need to make your fishing trip a success. Fishing boats are definitely the finishing touch to a nice fishing trip.
Dec 01, 2008 | Sea and Sea Sea Eagle Inflatable Fishing...
Computers & Internet Logo
219 people viewed this question
Alun Cox
David Payne
David Payne
