Question about Craftsman 25cc Gas Line Trimmer
Diagram for craftsman line trimer i need to take it apart
    Problem Solver:
  • 19 Answers
You can find a diagram for your trimmer at the Sears PartsDirect website at www.partsdirect.com.
Posted on Dec 13, 2010
I need a manuel for a Weed Eater String Trimer model W25SKF Speficically the primmer bulb to the carberator
Not sure what you are trying to do or if this will help, but it is a parts diagram of every part. The next is a You Tube video that shows how to take apart and many more weed eater videos to choose from.
http://m.tractorsupply.com/ProdContentPDFs/4041511_Man1.pdf h
How to Replace Trimmer Fuel Lines
May 05, 2015 | Garden
Where to place fuel lines on a craftsman chainsaw model 358.352161?
http://www.ereplacementparts.com/craftsman-358352161-gas-chainsaw-parts-c-158286_172209_172289.html
The above link will take you to www.ereplacementparts.com
They sell all of the parts for your saw. There is also an exploded diagram. I am not sure if it will help you, but it may.
The other place I would try is YouTube. There are many videos on chainsaws.
I hope this helps and god luck with your saw.
Jul 09, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Trere are lines running up and down half way across the screne they are colorful.
Try to adjust the vertical hold trimer.In adjusting the trimer you look the screen while adjusting the trimer until the screen or picture back to normal.
Jul 04, 2011 | Hyundai HPT-4250 Television
My trimer dont' have spark wen y pull the rope
pull the the kill wire off at the kill switch or button make sure wires cannot touch earth - retry for spark , check ht lead for grounding somewhere if ok try new plug if still no spark - replace ignition unit then reconnect wires
Aug 03, 2010 | Craftsman 25cc Gas Line Trimmer
I have a craftsman 32cc weedwacker line trimer. Having trouble starting it. I noticed that the fuel lines didn't look to good so I replaced both. Installed a new spark plug and put in a fresh tank of gas...
Sounds as if the Carb needs to be cleaned out. Get yourself a can of non-chlorinated brake cleaner and spray the carb out really well. Then reinstall the carb. Also check any ports in the carb to make sure there isn't any debris blocking the flow of fuel. I would also suggest getting some Stabil Marine (blue) fuel stabilizer. The ethanol in gas destroys small engine carbs. Just mix this in with your gas tank the next time you fill up. How old is this fuel? The ethanol also absorbs water, so even while in the gas can it is obtaining moisture. The Stabil Marine formula helps lesson the effects of the ethanol.
Aug 02, 2010 | Craftsman 25cc Gas Line Trimmer
I need a carburator for my craftsman line trimer
You can get those online. Take the carb off and clean is so you can see the name and model of the carb. Once you have that, just go online and find the part. I sometimes use jackssmallengines.com. I get the correct part in a timely manner. Good luck...Lee
Nov 05, 2009 | Craftsman 25cc Gas Line Trimmer
Need new spool, will not feed out linecraftman trimer,edger 17-25cc
go to sears parts direct and use your model number to get parts
Jul 15, 2009 | Craftsman 25cc Gas Line Trimmer
New fuel lines, wont stay run, swapt in/out line, wont stay run
Sometimes simply removing the carb and placing it in a carb dip will clean it without tearing it apart, also check or replace the spark plug. Make sure you have compression, good spark, and that fuel is getting to the carb. If that doesnt work, email me and I'll find you a diagram. Jblee1975@yahoo.com
Jul 11, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
537 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
