Magic Chef CTB1821AR Top Freezer Refrigerator Logo
Posted on Aug 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 13 month old apartment size Magic Chef refrige. It stopped geting cold about 1 month age. I uplugged and it work fine for until now. Same thing. Left it unplugged for a while and now it works fine.
Level 3:
  • Magic Chef Master 17,130 Answers
  • Posted on Aug 03, 2010
Magic Chef Master
Level 3:
Answers
17130
Questions
0
Helped
3632975
Points
52372
The fault is very much with the auto defrosting of your fridge. When the firdge stops cooling you are unplugging the fridge to allow it to defrost. As there is so much frost in the cooling coils there will not be any convection of the cool air from the coil as it gets blocked. So after defrost the coils get cleared and works fine till the next time frost appears. So first of all remove the freezer compartment rear covers to access the cooling coils, check for break in wires to thermostat, to the deffrosting heater or open coils in the heaters.Now trace the wires to the defrosting timer which is a 8 hours timer for defrosting the coils by the heaters. You can see if the timer is working. Now one of these could be the culprit but you will have to make sure by testing each one and confirming before replacing. Please do this step by step. Hope you get it right. If not familiar get help. Good day
I have a magic chef refrigerator.Model number CTL1911DEW. compressor is fine, freezer is fine. Light is off on refrigerator thermostat and its not getting cold D
There is a fan which brings cold air from the freezer side to the refrig and sounds like it is not running.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
On a Magic Chef # RB21K4AF where or how do I get the the evaporator fan for the refigerator compartment, the freeze is fine and I can feel cold air blowing from the vent holes in the freeze
The fan is working fine so leave it alone. If you have an issue in the fridge section not being cold enough it is because the damper mechanism that directs cold air down there is not working properly. Go here for diagram and parts Search Over 2 1 Million Appliance Parts
Hi i have a magic chef model # mcbr 1010b it was working great unti i left the door ajar overnight and now it gets very cold in freezer @ 0 degreeze and refrig part stays around 50 and seems like it will...
Since you left door open I think the evaporator is frozen up .Just shut it off for a while and let everything defrost then turn it back on and you should be fine
Age of appliance
At some point, you just have to decide if you want it or not. I can't tell you anything about it. If your friend bought it used, ask how long she's had it and estimate at least 5-10 years older than that. If it looks good, and it works good, and the price is right...... I have one similar to the one that you are considering out in my garage. Bought it at a yard sale...$40.00. Not too pretty, maybe from too many moves....Works fine, but if it died tomorrow, I have had my money's worth.
Sage advice from W/D
1helpful
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Magic chef- apartment size
The unit is sealed most tecks will not recharge to small to deal with. Most common cause for this is low freon. If someone has a clamp on amp meter the wire leading to the compressor will probibly show very low amps. showing a free flow compressor. Cheaper to replace.
Top Magic Chef Refrigerators Experts
Kardoc
vince
Paul Carew
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
