Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
Hardware installation not success , while inserting the Sandissk Cruzer Blade pendrive.
    Problem Solver:
  • 7 Answers
How's it going? The Sandisc Cruzer is a nice pendrive. Try this. On your computer, Turn off all "auto run" & save any files from the cruzer you want. click start>computer, Insert the cruzer in a usb drive. Watch the screen & see what drive it installs in. Let it complete this process. Right click on the cruzer, Go down & click on "properties." Click on tools>error checking. scan for errors. When done, click, okay. Right click on cruzer again & click, format. This will delete any files you have in there that's why we saved files earlier, right? Formatting will Right any Wrong so to speak & get your cruzer for use. When you download, download to your computer, Save it. You could scan it for viruses etc at this point. Then you got three choices, You can send it to cruzer,(right click on the file & go down to send, & sent it to the drive cruzer is in.) or, you could, "copy & Paste," it on over to cruzer. And last but not least, you could, "drag" it on over to cruzer. Once you got it over there & you are ready to leave. Right click on cruzer, go down to, "eject," or, "remove." & wait until cruzer tells you it's okay to safe to remove. This is most important because if you just yank it out, you could be ruining some files on the cruz-miester. So try this & Good Luck! BRUTUS X
Posted on Aug 03, 2010
My toshiba 8 gb pendrive is not recognised by desktop,
does this pendrive work on other computers if it does then use a different usb port if it wont replace pendrive
Aug 01, 2014 | Microtoolz PenDrive Autorun
MY 8GB SANDISK CRUZER BLADE PENDRIVE NOW SHOWS WRITE PROTECTED...PLEASE HELP IF U CAN........
My 8 Gb pen drive now right protected how can i remove the write protection pls.....................Pls..............say the solution
Sep 13, 2011 | SanDisk Sansa e270 MP3 Player
When I insert sandisk cruzer blade 8gb pendrive, it is showing as removable disk but not opening and shows as 0 bytes. All other pendrives are working in my system and this pendrive is working in other...
Since it works with other systems there is a system incompatibility issue. Are you using the same OS in this machine as in the others where it works? Could it be that?
Using XP? It has some issues with some usb devices.
Sep 23, 2017 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
When i am inserting my sandisk pendrive its getting heated up and not detected as a disk drive...How to resolve this problem
Most possible that the pendrive hardware has failed, there seems to be SHORT within that is heating the pendrive. As these are small devices with high density packs of components the component level service is not an amateur job. So refer to Sandisk local support and see if you can avail the warranty or free replacement.
Jul 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
When i am inserting sandisk cruzer blade 2GB pendrive in my laptop, error message is coming 'the device has not passed windows logo test" and then asks to install the driver. again the message...
Go to the link below and scroll to the bottom of the list and you will find the cruiser line of devices. Download the driver for your device. Install the driver and the insert your flash drive. You are off to the races. Let me know if you need more help:
http://www.sandisk.com/sandisk-support/driver-download-wizard
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 08, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My cruzer blade sandisk 8 gb pendrive is very slow while writing in to it. pls give solution
insert 2 GB USB click start control panel administrive tools computer management disc management you can defragment this USB drive or you can right click select properties tools check now tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files or tick in one box then return after it has fixed the first task then tick the other box
hope this helps
Mar 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Hai, i have a sandisk cruzer micro 8gb
Well I had this problem twice
1: put flashdrive in washing machine
OR
2:go to installed hardwAre panel (something like that) and uninstall the hardware then reinstall ( by reattaching drive)
Honestly I don't recommend option 1 ... But that works too
Mar 03, 2011 | SanDisk Electronics - Others
SAN DISK PEN DRIVE troubleshooting
When i connect the pendrive into the USB drive the indicator light doesnt glow on pendrive and no "new hardware found" message appears on the screen.
Mar 18, 2008 | SanDisk Open Box 1GB Cruzer Mini...
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
518 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
