Question about Gateway GTW-P42M102 Television
The menu pops up on starting and continues to scroll. The front panel buttons on the TV do not do what they are supposed to do (i.e. Vol button changes input option, etc.)
I have the gtw-p42m102 and it did the scrolling thing and i had the image board dpwb11393-1g-l changed and it worked fine for 2 years.Now it made a pop like a firecracker and i am working in it now.
Posted on Aug 29, 2010
I can't enter service menu on Sharp TV 60LE751
Give this a try...
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu
Mar 22, 2014 | Televison & Video
Dont have the remote control cant turn to channel 3 or 4 dont have a menu button
Isn't there a channel Up/Dn button at the front panel of this TV. It should be there. Only Menu button is not. There is Ch up ' Ch Dn and Vol Up ' Vol Dn buttons, beside a power button. Even pressing the channel Up ' Dn button, the channels cannot be changed, check the micro switches inside the TV. Replace them all at one time. You ave to open the TV to access these components.
Aug 02, 2012 | Sylvania 6719DF 19" TV/VCR/DVD
Bush tv tuning to arerial
Hello
Connec the external areal to its ariel socket at its back side, and get into its meny option, select 'autotune', and press vol (+) button on the remote control. If the set ahs a 'Menu" button on its front panel, you can do this by pressing the Menu button, surf thorugh, select autotune and press Vol(+) button once.
Feb 28, 2012 | Bush Televison & Video
We lost the remote and we are trying to hook up our Wii to the front panel box. How do we change the input to the front panel without the remote
On the side of the TV there are a set of buttons. An Input button is next to the Menu button and will let you access the different sources connected to the TV. For the front panel input, look for the source labeled Front. (There are also volume control and channel +/- buttons.) The button order is Input, Menu, Vol -, Vol +, Ch -, Ch +.
If you want, you can get a substitute remote that is guaranteed to match the original remote's features here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=32V524T&uuid=12935850039140 .
I hope this wants.
Dec 29, 2010 | RCA 32V524T TV
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
Menu Screen pops up, try to exit and goes to video 1
This could be a stuck button on the front control panel or a bad solder connection on one of the switches on the front control panel.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
AV input selection without a remote
I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
Jan 24, 2009 | Televison & Video
Front buttens locked and no remote rca d52w19byx1 itc222
when using your remote once you get to where you want to Go to adjust press channel up & down buttons this will let you scroll up and down and then use vol- vol+ to make adjustments.use buttons on front of tv.ThankYou for using FixYa.Have a Nice Day.
Feb 05, 2008 | RCA D52W19 52" Rear Projection Television
No remote
If you have a menu button on
the front panel you can by
using the ^/v </> buttons
(ch up ch dn vol up vol dn)buttons
to navigate the onscreen menu
If not you will need to purchase a
universal remote with a menu set
enter tv/vid pip button and a working
code for your tv you may have to try
more than 1
Nov 20, 2007 | Sony KV-13M10 13" TV
Open Questions:
Televison & Video Logo
116 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
