Question about Dryers
How to tighten a loose dryer drum - Dryers
  • skydove721 Sep 21, 2008
    I have a neptune elec dryer and the drum is loose and making a loud noise with running, how do i tighten belt?
  • Anonymous Mar 31, 2014
    Its a kenmore dryer model # 41782042101
    Genius:
  • 1,073 Answers
What is the model number
Posted on Apr 25, 2008
Kenmore elite steam dryer replacing a baffle
Remove the top and you will be able to see the side of the drum- rotate it until you expose the screws to the loose baffle.(tighten them all while you are in there) Drum Baffle WPW10112972
Jul 09, 2016 | Kenmore Dryers
Mod 110.67741600 ser mu2020976 dryer drum is makeing a lot of noise
Check the baffles in the dryer drum to see if any are loose. If they are not loose, spin the dryer by hand to see if noise is from inside the drum. Sometimes you will get coins caught in the baffles and all you have to do is loosen the screws, and rotate the drum a little so the coins will fall out. Then tighten the screws up and replace the cabinet. You may also have a bad drum roller inside the machine.
If you could describe the sound to me, I will be able to help you a little more.
Jan 06, 2011 | Kenmore 700 6973 Dryer
Inside the dryer there are 3 bars that stick out to help tumble the clothes. One of them has come loose and I'm not sure how to tighten it. It appears to be attached with screws that come thru the drum...
With the front off look up in the top left and right corners for some screws that hold the top of the dryer to the side panels. Depending on your model, there can be different styles. The old maytags used 3/8 in screws up inside the corners and the newer models had 5/16 screws right up front.
Once you get the front of the top loose you will be able to lift it like the hood on a car to gain access to the drum.
Rotate the drum by hand to put your loose fin at the top and tighten up your screws. Sometimes the screws will round out the holes on the drum too much and you may want to put a washer on the screw to secure it better.
Oct 07, 2010 | Maytag Dryers
I have a maytag neptune dryer and the drum is loose how do i tighten it?
Why do you say that the drum is loose? Are you able to wobble it by hand? If so, that is evidence of a bad roller that the drum sits on.
If the drum doesn't turn as fast as it did, that is probably a loose belt, which would indicate that the belt tensioner is not working or belt has jumped the tensioner.
Jun 13, 2010 | Maytag MDE2400AYW Neptune Electric Dryer
Fin inside dryer drum loose and rattles can it be
get to out side of drum and tighten screws
Apr 25, 2010 | Dryers
Fin on gas dryer loose.
The model number is generally inside the door or door jamb area. The top must be removed to access the drum to tighten the screws to the fin
Apr 15, 2010 | Maytag SDG4606A Gas Dryer
Rattle inside dryer drum
remove the front cover and then you can access the top cover screws to open top then you can locate and tighten screws
Jul 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
Kenmore Elite Dryer Blower fan is loose
in the back opf your dryer the drum runs on 2 black rubber wheels when they are worn out it will giveyou that kind of noise replace them they cost about 8.00 each there is two of them you van see one from the bottom right side in the back of the drum if you remove the front lower panel thanks from gilles
Mar 15, 2009 | Kenmore Elite HE4 Electric Dryer
Drum rubbing on inside walls
Go into the back of the dryer. Remove access to back and you will see the drum. Chances are your motor that turns the drum is loose or the shaft or spindle that the dryer spins on is loose from its bracket. Tighten all that up and it should be fine.
Jan 30, 2009 | Dryers
Dryers Logo
308 people viewed this question
Top Dryers Experts
