WATER LEAKS FROM ALL OVER ON THE BOTTOM OF AIR CONDITIONER.WITH THE WINDOWS I HAVE, I CANNOT TIP A/C TO DRAIN OUTSIDE.WITH THE WINDOWS I HAVE, IT JUST UPRIGHT IN THE WINDOW. IT ALSO ICES UP A LOT. THANK YOU
    President:
  • 2,976 Answers
Air conditioners MUST be tilted to drain. If not, they will drain into the room. Try shimming up the inside of the window sill with a few thin boards. The ice problem is either because it can't drain or, it is too small for the area being cooled.
Posted on Aug 03, 2010
Testimonial: "VERY GOOD ADVICE. I WILL GET IT TILTED SOMEHOW. THANK YOU VERY MUCH!!DAVID E SOWERSBY"
Leaking water
Connect the proper sized tubing, and run it to a desired drain area. Make sure no outside air is entering the conditioned space.
Aug 30, 2013 | GE APN08AA Portable Air Conditioner
Midea portable air conditioner leaking water from bottom
Do you have it tilted back slightly towards the outside? It will drain on the inside if not tilted properly.
May 05, 2012 | Amana Heating & Cooling
My Mitsubishi Split air air Con leaks water (condensation) when operating. Every month or so I have to clean the water tray of water and blow out the drain pipe. It appears that on indstalation the...
Please note the drain line should be always downwards to flow water freely. Now you lift the indoor slightly from down locked, and take drain line out through any side of indoor. Now just after 6 or 9" after make hole (levelly down) and insert to outside. Or From outside, existing drainline can be run down words. Thanks.
Feb 26, 2011 | Mitsubishi MS09TW Air Conditioner
Free standing Convair Supercool leaks like a sieve! We have no manual. Does the small black hose pipe drain the water from the white pipe at the bottom rear of the unit [ where most of the water is coming...
The water is being generated from humidity inside the air. The air conditioner also acts as a dehumidifier. The black line is the drain. The drain line needs to go to an outside line or to a container to collect the condensated water. With low humidity levels, the water will evaporate back into the air. With high humidity, the water is removed from the air at a higher volume than can evaporate back into the air.
Jan 29, 2011 | Convair Portable Air Conditioner
Water leaks out all over the floor from the window air conditioner
you need to make sure of two things.
1) the AC is 'tilted backwards' just a little bit - to allow the water (condensate water from the evap coil) to drip from the bottom of the AC - out the 'condensate drain hole' - sometimes into a drain hose (usually rubber) or just through the hole to somewhere outside where it doesn't hurt anything.
2) make sure the - condensate drain hole, and drain hose - (if one is used) is clear and not clogged up - to allow the condensate water to drain.
hope this helps
Jun 26, 2010 | Haier hwr10xc6 Air Conditioner
Condensation leaks out front of unit into the house.
Hi, no don't drill holes in bottom tray, to make drain, that's design, you need to keep water there, the fan usually pick up water(moisture) and add to your air inside your home, otherwise the air in your home will become to dry, dry air will create static electricity all over your home, from your carpet to your clothes, you need to level your unit horizontally, put a spirit level, and you should have a slight pitch, from front to back, good luck.
Aug 03, 2009 | Maytag M6Q10F2A Air Conditioner
My Air conditioner leaks water
All A/C units drain water and need a clear path to drain water.
If window unit the unit MUST lean to the outside so the condensation water can drain that direction and insure the drain hole is clear of debree.
If an indoor central a/c unit the drain must be clogged the unit is leaning away from drain or the pipe going to the drain is clogged somewhere as it exits house. Cant drain if doesn't have a clear path to do it's job. Doubt it's a problem with the brand.
Aug 02, 2009 | Kenmore Heating & Cooling
Condensation causing water collection
Hi there!
Make sure the unit is level and not tilted forwards.Tilt back if anything.
There should be a drain hole at the back, but it may be clogged, or there may be an obstruction causing the water to build up.
In times of high humidity, water will condense on the cooling coils, and drip off. This is usually carted away by means of a tray flowing to an outside pipe.
One design uses a flinger to catch any water and throw it onto the evaporator coils - thus improving efficiency, but if there is anything touching the coils, like a feather etc, it will flow down that and leak.
Tip it back as the first action, then investigate if it doesn't drain.
Jul 06, 2008 | Samsung AW0503B Air Conditioner
Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
