Question about Kenmore Dishwashers
The lock on light wont go off. We can not start the dishwasher. We have tried holding the noheat option for several seconds and have turned off the circuit box for several minutes and neither one made the lock on light stay off.
  • 5,081 Answers
That is the correct button to push to turn the control lock off. You can try to reset the control by removing power for two minutes. If the dishwasher is doing the same thing, most likely the touch pad has a shorted button or a bad connection on the unit control board. To check touch pad connection you will have to open the console. You will want to turn the power off to the dishwasher first.
Open the console.Once the console is open, remove and install the ribbon cable a few times. Now put the door back together and restore the power. If the dishwasher works, it was just a bad connection on the ribbon cable. If the console is doing the same thing, it could be a console or a unit control faulty. I recommend the console first.
Posted on Aug 03, 2010
WDT790SAYMO dishwasher will not start. Appears locked. Help
Control Lock On
Use the Lock to prevent your dishwasher from accidentally being turned on. Use the Lock, also, to prevent accidental cycle or option changes during a cycle.
LOCK ON
When LOCK ON is lit, all buttons are disabled.
NOTES:
The dishwasher door can be opened while the controls are locked.
You can turn on the Lock while the dishwasher is running.
To turn on the Lock:
Press and hold NO HEAT DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light flashes 3 times.
To turn off the Lock
Press and hold NO HEAT DRY for 4 seconds. The light turns off.
If the lock light flashes constantly this indicates that a key (or keys) is most likely shorted or stuck. If this is the case the console or touch pad must be replaced. The console is only available in black (part number 3384340).
Jul 31, 2017 | Televison & Video
How to program the safety lock on and off model 66517039402
From Page 15 of the complete owners manual available here:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0409033.pdf
Lock On
Use the Lock On to prevent unintended use of the dishwasher.
You can also use the lock feature to prevent unintended cycle or
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
flashes 3 times.
Press and hold HEATED DRY for 4 seconds. The light turns off.
Sep 24, 2015 | Kenmore Dishwashers
The control lock light is on and the machine wont start
You should be able to toggle off the Control Panel Lock by pressing and holding the Energy Saver Dry pad for 4+ seconds. If the light doesn't go off, try shifting your finger position on the touch pad. I have a few appliances where the angle pressure has to be just right for a "press and hold" to be recognized.
If several attempts fail, the keypad, wiring or the main board aren't communicating properly. Please check the model number of the dishwasher; there are several KUDS01FLSS models. Go to http://www.kitchenaid.com/customer-service/manuals/ and enter the model to get the parts list. Some parts are available from Appliance Parts Pro: http://www.appliancepartspros.com/search.aspx?model=kuds01flss . The user interface is here: http://www.appliancepartspros.com/whirlpool-user-interface-8270168-ap3085303.html .
I hope this helps.
Nov 19, 2014 | KitchenAid 24 in. KUDS01FLSS Built-In...
Why is the lock light on
Look on the front for the buttons that say lock press them at the same time and hold for several seconds the light should go off. If that won't work try to turn off the power for several minutes then restore power.
May 14, 2014 | Kenmore 24" Built-In Dishwasher with...
Blinking auto lock Whirlpool
What does it say in fine print right under control lock? "Press & Hold"? Page 16 of the user manual shows it as "air dry" with two lights, twelve and three o'clock positions. It says hold it for four seconds and the light turns off.
Aug 20, 2012 | Whirlpool GU1200XTLS Stainless Steel...
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
To turn on the Lock
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
The control lock on button will not go off
I've tried the NOHEAT button but I just get a few blinks on the lock light and the problem persists.
Any Ideas?
May 23, 2008 | Kenmore 16919 Built-in Dishwasher
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Dishwasher "lock on ' control wont turn off
Hold the control lock in for more than four seconds. See if that works.
Jul 25, 2007 | Kenmore 15762 Dishwasher
Kenmore Ultra Dishwasher. Model 665.15772990
There should be a button on the machine with a padlock symbol. Hold it down for 4 seconds to unlock it. If you want to lock it again, hold it down for 4 seconds to turn it on.
Jun 01, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
105 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
