The sensor for the remote control went out about 2 months ago also. No remots work with the tv anymore. Now the power won't turn on.
  • 49 Answers
PLEADE CHANGE THE CRYSTAL 455MHZ AND REMORED LED.
Posted on Aug 03, 2010
I bought a seiki 48 inch TV about 2 months ago. Now the remote has stopped working. Any ideas
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Aug 20, 2015 | Seiki Televison & Video
What is my tv code for programming my dish network remote.
Hi!
Welcome to FixYa!
You can use these codes to program the Dish remote control to your Sanyo DS32920:
542, 589, 590, 591, 592,609
You may also try Power Scan Instructions. Please follow the steps bellow.
1. While at the TV locations (TV1 or TV2 depending on which key is installed), point the remote at the TV. Press and hold the TV MODE button on the remote until all four MODE buttons at the top of the remote light up.
2. Press the RECEIVER POWER button on the remote.
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the TV turns off. This process may take several minutes.
4. Press POUND (#) on the remote. The TV MODE button will flash three times.
5. Press TV POWER on the remote to turn on the TV. Press VOLUME on the remote to confirm the remote controls the TV. If this does not work, return to Step 1.
Keep me posted.
Thanks.
Lor04
Apr 07, 2011 | Sanyo DS32920 32" TV
I tried to change the channel and doesnt work anymore before the problem the red power light was on
i accidently hit the guide button. now i can't do anything with it.no sound or channels.my tv is an emerson,my device is a #6.ijust bought it about a month ago. thanks
Nov 08, 2010 | RCA RCR311B Remote Control
So i went to turn on my hom theater and it didnt trn on i had 2 do it manualy the remote worked fine hours ago not it doesnt
Try replace the batteries with fresh ones and installed correctly,check to see that the LED lights up when you press a button, and that nothing is blocking the signal IR path to the sensor on the TV,and that your not to far away from TV.....hope this was helpful....
Jun 02, 2010 | Samsung TV Remote Control
Cannot control tv with remote. took remote to my son's house and it worked his tv ok ( same model). Seems it might be a tv problem and not a remote problem. It happened about 3 months ago and then kinda...
the fault is from your the TV sensor. Your remote sensor cannot sense the TV sensor, that's why the remote or any other cannot control your TV.
So its a remote sensor problem.
Take care.
Mar 12, 2010 | LG 32LC2D Television
Remote Control does not work
well probally not dust sounds like a bad reciver i just fixed one about a month ago
Apr 03, 2009 | Sylvania SRC22134 13 in. TV/VCR Combo
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
Remotes no longer work
I had this exact same problem. After a week or so it started responding to the remote control again. Then after a couple of days it stopped responding. This problem came and went for about a month, then one day the entire TV went dead. When I powered it on, the green light appeared for 2 seconds followed by a sequence of 6 flashing red lights that repeated. I brought my set in to a repair shop and they replaced the power supply board. That fixed the problem and now the TV powers up and responds to the remote control again. Total charge was $250. That was very disappointing for a $1,500 TV that was only 18 months old. I'm going to let Philips know how disappointed I am in their product!
May 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Everything slowly went wrong
Most likely you have a locked up micro on the main board. You would need to have the main board replaced. If the set is not under warranty your cost to repair would exceed your cost to replace.
Sep 11, 2007 | Insignia IS 20" TV040919 TV
TV doesn't recognize any remote
The proble is the IR sensor 932220681667 or the small signal board. I would replace the IR sensor first. Also check the firmware and make sure it is BX23U-1.5.0.0_03531 and if it is not go to www.usasupport.com and down load the firware on a USB stick. If the set still has the problem when both are done replace the small signal board.
Jun 17, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
