Question about HP OfficeJet k60xi InkJet Printer
Office Jet K60xi Scanner Failure
I have a copier/scanner/fax that will print from my computer but will not scan for copies or fax. It give the message "Scanner Failure. Power off and then on again". I've done this several times with no results. I still get the same message. How can I fix this?
  • 4 more comments
  • Anonymous Jun 13, 2008
    will the scanner work with vista? i can print and fax but only scan through my picture program
  • wlbagwell Jun 23, 2008
    I ;can copy and I can copy from the computer. I can not scan to the computer. When I try I get scanner failure, turn off and restart. Does not not help at all.
  • charliemec Aug 21, 2008
    I get "Scanner Failure" message when I attempt to copy or fax. I can print from my computer but I cannot copy or receive faxes or send faxes via the HP OfficeJet k60xi inkjet product. I have been unable to get an answer to this problem. No one appears to have the knowledge to fix this issue. Can you help?
  • Jefferson Casavant
    Jefferson Casavant Dec 18, 2008
    My problem is slightly different.  When I load the original document to copy from, it emits a growling, crunching noise as if a motor inside is not working.  I do not know how to get to the motor to fix it, or replace it.  Can someone enlighten me?
  • Anonymous May 20, 2009
    I experienced the same issue after I changed from VOIP back to hard line phone service. The modem was near my All Function HP Printer and it seems that the technician bumped or changed the electrical connections. So far, I have fixed it by unconnecting/reconnecting and/or changing electrical connection location. It seems that when voltage is low, the print from computer function can work fine but the copy/scan/fax function gives the error message identified. Other things listed by HP as being potential causes are wrong power cable, bad power cable contacts, failed or deteriorated power converter, bad house current etc.
  • Anonymous Mar 23, 2014
    i tried to connect the copier to my computer - since then it has come up with a scanner failure error - could the two be related - how can i fix it - is there a solution
    President:
  • 2,351 Answers
Try HP's web site suggestions first.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077492&cc=us&lc=en&dlc=en&product=61736
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site. http://welcome.hp.com/country/us/en/welcome.html#Support
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Posted on Apr 25, 2008
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
Try to copy and get scanner failure motice
scanner failure is a hardawre problem. try to copy again and check if the scanner light is on. once the scanner light is not working then try to return your printer in the store that you have purchased it.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanner failure message
the main system is faulty same thing happened to me.
Aug 14, 2009 | HP 7210 OfficeJet All-In-One Printer
HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
Scan failure
try scanning from your printer/scanner program on the computer. My scanner will not work stand alone, but does work this way
May 11, 2009 | Office Equipment & Supplies
How do I use my HP office jet v40
Install software from disk or download from HP site
Apr 24, 2009 | HP Office Equipment & Supplies
Try to print--scanner failure appears
I think your printer has been, for some time now, trying to tell you something and the scanner failure message
is the last in a series of messages.
First, the copier and the printer and the scanner worked fine, "for years",
Then, the copier stopped accepting scans, while printing from data sent by your computer.
Then, you received a scanner failure message again, and will not accept data from your computer, and
"won't print at all"
Your printer/scanner/copier/fax has needed service for some time after years of continuous service.
Evaluate now, based on its initial cost and the lesser cost of All In Ones whether you have already
obtained sufficient service to amortize the cost over time, and you may conclude that service is eitherr
cost effective or ineffective at this time.
Apr 17, 2009 | HP Office Equipment & Supplies
My Office Jet 7310xi scanner failure
Does it scan from either the doc feeder or from the flatbed itself?
Can you COPY a page?
Are you using the buttons on the printer, or do you work from HP director?
Mar 29, 2009 | HP Officejet 7310 All-In-One Printer
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet k60xi InkJet Printer Logo
440 people viewed this question
Ben Johnson
