Question about Whirlpool LHW0050PQ Front Load Washer
How touse whirlpoolwashing machine front load
How to use whirlpoolwashing machine front load AWG5061/M-600Rpm
i want to know about the useage of machine .
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Why does the whirlpoolwashing machine drain the water while i want to wash my cloths
Take a look at the drain hose on the back of the machine.
Most of those hoses are long black plastic.
The must be looped so that it goes higher than the top of the machine.
If the hose does not go that high before it drains, it will drain all the water out as fast as you fill it.
God bless your efforts.
Jan 18, 2018 | Washing Machines
What does the 40AA button do?
Lowers the temperature and prolongs the wash time in order to achieve a 40degree equivalent wash for cottons and synthetics with an AA energy useage
Jan 31, 2012 | Zanussi ZWF1430W Front Load Washer
My front loading machine washer did not have enough water to wash. water is very low almost low when i saw from front glass door. what hapening, how to adjust the water capasity.
No brand or model number supplied...
Front load washers use very little water. Most modern FL washers don't even fill to the bottom of the door, and it's easy to become concerned..I know how you feel.
If the machine is completing the full wash cycle, it's recognising that there is enough water to continue. Capturing and measuring the amount of water used, and comparing with manufacturers specificatrions can help.
If it stops mid way, it could be because there is a slow or faulty water inlet valve.
Check with the manufacturer/service agent to ascertain the water useage.
You may need to call a serviceman to physically check the machine, for your peace of mind...
Good luck Nomess
Aug 06, 2010 | Washing Machines
Whirlpoolwashing machine main bearing noisy can i
It appears your clutch assembly has failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
Jun 17, 2010 | Whirlpool AWM5125/1 Front Load Washer
Frigidaire Front Load Washer FAFW3574K - Is this a good washer, and how long should I expect it to last?
There are many things that can facotr into the life of a washer.
How many loads a week do you do?
What are the size of the loads?
What is the quality of the water?
Under many circumstances you can reasonably expect your washer to last 8-10 years.
The factors mentioned above can change that higher or lower depending mostly on your useage..
Heatman101
Mar 10, 2010 | Washing Machines
On/off light comes on but control panel is dark screen. Not responding. Belt was very hot last useage
It may have tripped thermal over load. Check for a manual reset on the lower front by where the cord connects to treadmill.
Feb 07, 2010 | Dmm Vision Fitness T9500 Treadmill
Dryer just stop working
check fuse, but this sounds more like an electrical problem on the motor, depending on how long you have had the dryer and useage it probably be the bushes which can be replaced by an enginneer.
May 12, 2009 | General Electric WPDH8800J Front Load...
WATER USEAGE
Depending on the age and size of your washer-Front loaders cut water use by nearly 40 percent. A typical top-loading washer uses about 40 gallons of water for each full load. In contrast, a full-size horizontal axis clothes washer uses only 20 to 25 gallons. That means that, by purchasing a horizontal axis model, you could save as much as 7,000 gallons of water per year. You also save all the energy you would have used to heat that water, meaning added savings for you and a big boost for the environment. These appliances also use less energy than conventional washers - approximately 50 percent less, according to the Environmental Protection Agency.
Feb 10, 2009 | Kenmore Washing Machines
Shows "LE" in display.
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
80 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
